All-Or-Nothing Posted June 22, 2014 Report Share Posted June 22, 2014 So I downloaded Sketchup and pulled up the spec and cut sheet for the E8 dual box. I need my box to be maybe 4 or 5 inches shorter height wise. Can I take out 5 inches from the height and just add that back in to the length of the box. Will this mess up the port lengths and change where the box is tuned? I have plenty room width and length wise it's just the height that is too much. Here is a screen capture of the box I want to run... Here is what I am running now. Quote Link to comment Share on other sites More sharing options...
youngbass98 Posted June 22, 2014 Report Share Posted June 22, 2014 for your questions none of what you mentioned would work. just out up a thread in the enclosures section, put up your max demenstions and I am sure some one would be nice enough to make you a design Quote 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt Link to comment Share on other sites More sharing options...
MurdocGTP Posted June 22, 2014 Report Share Posted June 22, 2014 I am not sure what's up with these sketchup diagrams on Sundown's site. It's the same cutout sheet for the E8, SD-2 8 and the SA8. Maybe these diagrams are just giving a general idea but i am sure they each require different specs to run effectively. I built my first box (first one ever) a few weeks ago for a couple of SD-2 8's i have on order and I just used a combo of youtube, forum posts and torres. There's alot of info out there for box building...even for specific drivers like the E8's. Quote Murdoc 06 civic sedan alpine cde-hd149bt sundown sax 150.4 sundown 6.5cs sundown sd-2 8v2 (pair in a sealed box) Link to comment Share on other sites More sharing options...
All-Or-Nothing Posted June 23, 2014 Author Report Share Posted June 23, 2014 for your questions none of what you mentioned would work. just out up a thread in the enclosures section, put up your max demenstions and I am sure some one would be nice enough to make you a design I made a thread like you suggested. I also found a website...The Box Guy....looks very good. Quote Link to comment Share on other sites More sharing options...
All-Or-Nothing Posted June 24, 2014 Author Report Share Posted June 24, 2014 Hmmmm..........seems like my thread for a box design was deleted. SMH Quote Link to comment Share on other sites More sharing options...
