Would a Change be Beneficial?
dawgs007
I currently have my Power Acoustik Mofo-122X wired to 2ohm. Would it be beneficial to switch up the wiring to 1ohm? The difference is 900W at 2ohm to 1200 at 1ohm. And if I provide the link (http://soundstream.com/store/car-audio/amplifiers/picasso/p1-1200d.html) could you guys tell me if the amp is stable at 1ohm? It gives 1ohm rms but doesn't state if it's 1ohm stable on a single 2-ohm DVC sub.
A response and diagram on how-to would be great (I'm still in the learning process, immensely).
Thanks in advance!
Current Setup: 2002 Ford Focus SE (stock electrical)
-Kenwood Excelon KDC-X397
-Infinity Kappa 6x9's in each door
-Rockford Fosgate Prime R1200-1D
-2 12" Rockford Fosgate P3D2
Backups:
-12" Power Acoustik Mofo-122X in 36hz T-Line box
-Soundstream Piasso P1.1200D
and run hotter. just be sure to use the DD-1 to get it set just right! make sure your using all the rated fuses as specified! and bump on! :nuts:
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
With that sub you can only wire to 4ohm or 1 ohm. So you probably are wired to 4ohm now. Then yes you will notice a difference wiring it down to 1ohm
truthsayer
Option 2 (series) = 4 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 1_2ohm_dvc_4ohm.gif
truthsayer
So, this is the recommended diagram to make it 1ohm?
Backups:
yes
Thanks a ton Truthsayer. This is the second topic you've helped me on! I'm currently on vacation but once I get home I'll let ya know if/what I change.
Backups:
  • Who's Online   2 Members, 0 Anonymous, 1096 Guests (See full list)
