help with voltage drop after upgraded alt and battery.
  • Replies 65
  • Created
  • Last Reply
your gauge on the dash is pretty accurate. the computer is not going to let your alternator perform nearly as well as it can.when i put my singer alternator in i didn't need a different belt or tensioner,dc may be different idk.all i can tell you is its not the alternator,it is the pcm. i dealt with this same thing for 4 years ,and i just dealt with constant voltage drop,lights dimming ect.contact dc and ask them about your truck being pcm controlled,and they will confirm your problem. i finally got tired of this problem and simply bypassed the pcm,now I'm at 14.8 all the time. your gonna need this and an extra battery for that amp.
I will call them tomorrow see what they can do but that's what I want to do I want to bypass the pcm I want to get the best out my alternator I was thinking of doing the mla module but where can I find one? and yes I will be adding another xs battery for sure just wanted to get this voltage situation fixed before I move forward
How are your grounds ??? something is not adding up here ...
just google mla module and call the number.the mla will trick your pcm into charging mode,they quoted me a couple hundred dollars for my truck.so i chose internally regulated alternator,it was included with my order.only thing with bypassing the stock plug is the battery light will light up on the dash. i thought this would bother me at first,but it doesn't. truck runs great with no problems and i haven't dropped under 14 since
Is there a way to test what my alternator is putting out?
Yes, ... find a place, like an starter & alternator shop in your area that has a Sun VAT45 machine, or the like, & they can test it ... usually while it is right on your car. Will give amp output & volts, etc.
You should get a printout like I did here back last year when I had a 170A MechMan in, now the 240A in, ... gotta take it back & see what it actually does with the MUCH better "Big 3" ...
55975b81-87be-4572-ac73-f7f7967bb92d_zps
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
That testing was done with nothing on, ... no system on, or major current draw ... Next time, with the 240A, I will use the system a bit & put some stress on it ...
Zeke
'14
Pioneer FH-P8000BT
kyle im going to fucking kill you. have your boy build an alt for his truck and see what happens..... same thing. the alt is controlled by the computer of the vehicle. it will turn off completely at times. it has nothing to do with the alt. its to "save fuel economy". you can thank GM for that
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
  • Who's Online   0 Members, 0 Anonymous, 217 Guests (See full list)
