FiCA Focus (first fiberglass build)
ok I probably shoulda started this thread a LONG time ago but I kept putting it off but I have been taking lots of pictures along the way so now that it's almost done I'll go ahead and post everything I've done so far lol
first of all... look at this sexy thing ;)
ok now for the box...
first, of course I did ALOT of taping
ran out of time and had to get to work...
and more taping...
and I actually even did a little more taping just to fully protect my car but didn't get pics of that...
then I started fiberglassing in the car to get the mold started...
I did eventually finish that layer of fiberglass but I ran out of resin when this picture was taken lol
first layer done and got it out of the car (had a bear of a time getting it out of the car with all the tape there sticking it to the car... was afraid of breaking something... finally ended up pulling the seat down and sticking a crowbar behind the box to peal the majority of the tape off)
did 2 more layers with the tape on then took the tape off and did another 3 layers!! (and yea for some reason it got kinda bumpy but since it's a sealed box I was told it wasn't that big a deal)
while those layers were curing took some time out to make a ring and lathered that in resin lol
then put it back to figure out how I wanted it shaped in the car and drew lines...
Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
My Build Log
now it's all ready to trim!! btw... turns out a circular saw with a diamond tipped cement blade works rather nicely as a grinder lol
now all cut and rinsed out of the sawdust (which I was washing out of my hands for weeks!!!) and stick it back in to check and make sure it fits how I wanted it to
then mounted the ring with some boards and wrapped the whole thing in Broncos fleece using a hot glue gun
covered the fleece in resin to harden the fleece before glassing
then did a layer of fiberglass and cut out the hole a little bit
did another 3 layers of fiberglassing on the outside and resin and another layer of fiberglassing on the inside and around the corners on the inside and did another test fit
next I took it out and got to work cleaning up the hole and sanding the whole thing, took a second to figure out that using the circular saw as a grinder for a round hole needed a slightly different tactic... so I messed it up at the beginning...
My Build Log
but after some practice and some using my brain pain I figured it out
then broke out the belt sander and got to work sanding stuff smooth (left it a little rough since I was using 80grit and the plastic in my car is rough too so thought it might look ok to keep it a little rough as long as it wasn't all bumpy)
lastly I broke out the good ol' rattle cans and did some paint work on it...
and wired and mounted the sub and put it in my car
haven't gotten any pictures of the rest yet but so far I have also:
installed a small battery in the back on the other side (mostly just to use to run wires to it to make it easier rather than running wires all the way from the front straight to the amp)
installed LOC and ran RCAs from LOC to the back
and ran 2/0 power wire through the car (just cuz I could and I still had some left over from my Taurus and they already had terminals) haven't actually connected either end to a battery yet till I get the back battery grounded and upgrade at least the ground on the front battery
now just gotta finish the easy stuff with the power wires (running grounds, soldering a terminal on the end of the power wire that I had to cut cuz it was 3ft too long) and then buy an amp and hook everything up
My Build Log
how does it feel.....
to suck at life that bad?
:wub:
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
yer just jealous cuz I'm gna finally be playing lol
My Build Log
Wow he made a build log. Looking good man!
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
lol ikr finally did it
My Build Log
Awesome man. Nice rebranded havoc you got there :peepwall: lol
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
lol yea whatever more like the other way around... and a failed attempt at rebranding at that
My Build Log
I'm just ducking with you man. You were the one who brought their differences to my attention.
Edit: dam autocorrect
Team Subsonic Lows
