audiofanaticz Posted September 8, 2014 Report Share Posted September 8, 2014 l don't understand, that how you tell the difference between the coils? You physically cant just buy looking at it through a vent hole on the woofer. You can easily tell upon building the woofer or if your cutting it apart for a recone. At those 2 times you can easily count the layers of windings around the former. The 8layer coil will usually be a little bit thicker due to it having twice the layers of wire wrapped around it. But this is not always true because sometimes it maybe 8 layers with a thinner gauge material making the outside diameter pretty close to the 4 layer coil with the heavier gauge aluminum wrapped around it. 1 Quote Link to comment Share on other sites More sharing options...
Larrykidluv Posted September 10, 2014 Author Report Share Posted September 10, 2014 l don't understand, that how you tell the difference between the coils?You physically cant just buy looking at it through a vent hole on the woofer.You can easily tell upon building the woofer or if your cutting it apart for a recone. At those 2 times you can easily count the layers of windings around the former. The 8layer coil will usually be a little bit thicker due to it having twice the layers of wire wrapped around it. But this is not always true because sometimes it maybe 8 layers with a thinner gauge material making the outside diameter pretty close to the 4 layer coil with the heavier gauge aluminum wrapped around it. Oookay! Quote Link to comment Share on other sites More sharing options...
meade916 Posted September 11, 2014 Report Share Posted September 11, 2014 I think I left it at zero, so if I drop it a bit I'll be okay? somehow, i doubt you own or have used a DD-1. If for some reason i am wrong, and usually i am not, than you probably did not do it right. "ummm i left it at zero"...LOL what? Anyone that uses 0db tracks at the amplifier level shouldn't have any problem with overpowering their subwoofers if they are properly matched (in specs) to the amp they are hooked up to. Even though i don't believe you know what i am talking about, i just want to point that out in case somehow i am wrong. But i doubt it. 1 Quote All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916 Link to comment Share on other sites More sharing options...
gmoxley1 Posted September 12, 2014 Report Share Posted September 12, 2014 I think I left it at zero, so if I drop it a bit I'll be okay? somehow, i doubt you own or have used a DD-1. If for some reason i am wrong, and usually i am not, than you probably did not do it right. "ummm i left it at zero"...LOL what? Anyone that uses 0db tracks at the amplifier level shouldn't have any problem with overpowering their subwoofers if they are properly matched (in specs) to the amp they are hooked up to. Even though i don't believe you know what i am talking about, i just want to point that out in case somehow i am wrong. But i doubt it. just curious steve as i don't own a DD-1 yet. (hopefully getting some money soon) if i'm thinking about this correctly 0db on the DD-1 would be less strain, for lack of a better word, than say -3 or -5 db? as in with the -3db you would actually be turning the gain up more as to account for the lower audio signal? is this correct? Im sure it says it in the manual but i am just wondering if i'm thinking of this the right way? Thanks Quote 1998 chevy blazer 4 door stock alt 105a Battery: Autocraft Gold 75-3 Big Three in Sky High Car Audio 4ga subs: rockford p2 12's (soon to be sundown SA 12's) Sundown SAZ-1200d on the subs Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash sae 50.4 for mids and highs SMD OM-1 on the subs Link to comment Share on other sites More sharing options...
n8ball2013 Posted September 12, 2014 Report Share Posted September 12, 2014 yes Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
hispls Posted September 12, 2014 Report Share Posted September 12, 2014 I think I left it at zero, so if I drop it a bit I'll be okay? somehow, i doubt you own or have used a DD-1. If for some reason i am wrong, and usually i am not, than you probably did not do it right. "ummm i left it at zero"...LOL what? Anyone that uses 0db tracks at the amplifier level shouldn't have any problem with overpowering their subwoofers if they are properly matched (in specs) to the amp they are hooked up to. Even though i don't believe you know what i am talking about, i just want to point that out in case somehow i am wrong. But i doubt it. just curious steve as i don't own a DD-1 yet. (hopefully getting some money soon) if i'm thinking about this correctly 0db on the DD-1 would be less strain, for lack of a better word, than say -3 or -5 db? as in with the -3db you would actually be turning the gain up more as to account for the lower audio signal? is this correct? Im sure it says it in the manual but i am just wondering if i'm thinking of this the right way? Thanks 0dB (the way Steve explained... which assumes your equipment is correctly matched and gives you honest power ratings) should make things retard proof. -3 or -5 (or more) would leave you enough volume knob for tracks with lower record levels and you'd be ultimately relying on your senses to tell you when you're over-driving things. At the end of the day, you can either make it retard proof and leave potentially 50-75% of your power on the table, or just rely on the ear-o-meter to tell you when you're at limits. OP definitely did not set gains with DD1 and 0dB tones.. Quote Link to comment Share on other sites More sharing options...
gmoxley1 Posted September 12, 2014 Report Share Posted September 12, 2014 sweet! thanks! Quote 1998 chevy blazer 4 door stock alt 105a Battery: Autocraft Gold 75-3 Big Three in Sky High Car Audio 4ga subs: rockford p2 12's (soon to be sundown SA 12's) Sundown SAZ-1200d on the subs Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash sae 50.4 for mids and highs SMD OM-1 on the subs Link to comment Share on other sites More sharing options...
Larrykidluv Posted September 13, 2014 Author Report Share Posted September 13, 2014 I think I left it at zero, so if I drop it a bit I'll be okay?somehow, i doubt you own or have used a DD-1. If for some reason i am wrong, and usually i am not, than you probably did not do it right. "ummm i left it at zero"...LOL what? Anyone that uses 0db tracks at the amplifier level shouldn't have any problem with overpowering their subwoofers if they are properly matched (in specs) to the amp they are hooked up to. Even though i don't believe you know what i am talking about, i just want to point that out in case somehow i am wrong. But i doubt it. Yes I do own a DD 1, and the gains are set on point. When said set it on zero I meant I set my amp using the -0dB. Quote Link to comment Share on other sites More sharing options...
