zxsonnyxz Posted September 5, 2014 Report Share Posted September 5, 2014 Finally started a new project im my "new" car! 1998 Omega B My plan is to keep building a bit over the winter and spring to get ready for next years car and car audio meets/competitions. This Isn't an spl oriented build as I want it to play low and awesome with a clear front stage, but I'll still do my best with what I end up getting. I'll be participating at least What I get as far as equippment will be revealed as I get it. I have a plan, but I might change my mind so I won't say anything just yet! What I am clear on so far is that I'm rebuilding my front doors, and that's where I'll start this project. The doors will house two 6.5"s each and I'll have a pair of tweets in either the a-pillars or in stock location if it'll fit. To begin with I'll see if my Tang Band speakers might work in a car, so you'll se those in the pics. So lets get to building This is what I have to work with Behind the panel and plastic Teardown ¨ Theese are the different parts the doors consists of, partly screwed and glued The glue was sto strong so I couldn't just pull the old fabric off On the bright side the resin etc. should get a good grip on this, might drill a few holes as well Theese are the parts I'll be altering, the rest will be left stock After I have my plan of attack, I'll get to making some speaker "rings" Made a little sketchup drawing to figure out my dimentions I spent som time making the first piece When it's done I'll use it as a template to make the others. This is much easier with the right tools so I made my own little thrown together router table Then I made the ruff cuts Put on some double sided tape Then let the flush trim bit do it's job Theese will be the outer rings. I used a rabbeting bit to get my desired inner diameter This is how they ended up with a little 45 for good looks 45'd the rear of the speaker holes Done, just need to be glued together Checking fitment The depth is alowing me to add some sort of speaker grille Just enough clearance for vinyl http://i1088.photobucket.com/albums/i326/Sondre_Tveit/Stereo/20140905_155205_zpsepgts3sx.jpg That's all I have for now! There will be updates as I make progress STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
77-AUDIO Posted September 5, 2014 Report Share Posted September 5, 2014 nice. need the list of router buts you used. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 5, 2014 Author Report Share Posted September 5, 2014 nice. need the list of router buts you used. A small straight/plain router bit for the circle cutouts Flush trim bit to copy parts Chamfer bit to make 45s Rabbeting bit to shrink parts STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 9, 2014 Author Report Share Posted September 9, 2014 Update time Figuring out placement, moved up 1cm from this The point of no return Building a base Needed two more of theese Put theese together with 4cm spacers at fiirst, but this isn't gonna work so I'll cut holes in the doors so I can shorten it down a bit. I think that would've been the best idea from the beginning. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 9, 2014 Author Report Share Posted September 9, 2014 Enden up with no spacing at all Holes Mounting for the "pod" Getting there One door ready for fabric and fibreglass, I'll do it while it's on the door so I'm sure to get good fitment. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 9, 2014 Author Report Share Posted September 9, 2014 Made a bit of progress on the other door as well Only missing the little mdf ring, then I can mount the rest of the door panel and get it ready for glassing STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
scooter99 Posted September 9, 2014 Report Share Posted September 9, 2014 Nice start on the doors. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 10, 2014 Author Report Share Posted September 10, 2014 A few minutes work later Then It started to rain After a little break I could continue Got ome fleece First staple Top row done, was a bit easier access without the top halve on Put it back on after I trimmed the fleece down Completely stapled After resin That's all I got done today Comments are welcome STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 11, 2014 Author Report Share Posted September 11, 2014 Now that it's hard it seems to be strong enough for me to take it of the door to lay down some fibreglass. Taken off and sanded down Two layers of mat It's coming along nicely I think STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
zxsonnyxz Posted September 15, 2014 Author Report Share Posted September 15, 2014 I have some more progress pics Removed all excess fibreglass Keeping the original mounting spots Not even a full layer of filler and the shape is pretty much there Continuing on the other door Had to do have a look at it If the resin actually hardens in this cold I'll be laying some fibreglass tonight STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback! Link to comment Share on other sites More sharing options...
