cashmoney229 Posted October 21, 2014 Report Share Posted October 21, 2014 Supplies: 1 mono block Amp 4 dual 4 ohm subs Ok You Know How A Mono Amp Goes ++-- I was wondering if I got 2 subs and wired them to 1 ohm and connect them to one neg and one pos then do the other 2 the same way and connect them to the other pos and neg on the same amp will that work to have 4 subs in one box 2011 Impala pioneer headunit rockford fosgate rca's audio control three.2 rockford fosgates T165&T1692 2 re audio sxx 15's hifonics brz24001.d crunch 1400.4 audio technix 10ga speaker wire & 0 ga power n ground Link to comment Share on other sites More sharing options...
BoomZoom808 Posted October 21, 2014 Report Share Posted October 21, 2014 Here are some diagrams. http://knowledge.sonicelectronix.com/tools/subwoofer-wiring/ 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
islandpride684 Posted October 21, 2014 Report Share Posted October 21, 2014 Supplies: 1 mono block Amp 4 dual 4 ohm subs Ok You Know How A Mono Amp Goes ++-- I was wondering if I got 2 subs and wired them to 1 ohm and connect them to one neg and one pos then do the other 2 the same way and connect them to the other pos and neg on the same amp will that work to have 4 subs in one box Final load will be .5 so hopefully your amp can handle it...amp is probably wired in parallel internally... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
AstoSoup Posted October 21, 2014 Report Share Posted October 21, 2014 What model and RMS amp do you have? What kind of subs and how many RMS are they? You have two choices, a .5 ohm load or a 2ohm load. Most amps cannot handle .5ohm daily, so I'm thinking your best bet is a 2ohm load. In this case, check the 2ohm RMS rating on your amp, divide it by 4 and that's what each sub will get. If it's much lower than what the subs are rated for, you will need a bigger amp or another amp. Here are the two possible wiring configurations.... http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=42#results Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
AstoSoup Posted October 21, 2014 Report Share Posted October 21, 2014 Ignore the 3rd, 8ohm option as it isn't needed in your application. Unless of course the amp is a DC 10k and the subs are Power Acoustiks, lol Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
reedal Posted October 21, 2014 Report Share Posted October 21, 2014 To actually answer your question, The ++-- on the amp is essentially a parallel connection. So two subs going to one +- and two going to the other is essentially all four subs going into one. Yes, you can have them all in one box and same airspace if it's on one amp SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 21, 2014 Report Share Posted October 21, 2014 You can have them all in one box and airspace even if its 2 different amps. You just have to gain match from there. Op, if you wire 2 subs to 1 ohm and anther 2 to 1 ohm then coonect the to Te same mono amp your dropping to .5ohms. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
AstoSoup Posted October 21, 2014 Report Share Posted October 21, 2014 You can have them all in one box and airspace even if its 2 different amps. You just have to gain match from there. Op, if you wire 2 subs to 1 ohm and anther 2 to 1 ohm then coonect the to Te same mono amp your dropping to .5ohms. If he does with series/parallel, it will be a 2ohm load.... Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 21, 2014 Report Share Posted October 21, 2014 Yes but he was ask g if he wired 2 pairs of subs down to one then connects both to the amp if it will work. That would give him a .5ohm load. Maybe the amp can or can't handle that. Best way to find out is try. However I isn't recommended. At that point your throwing the dampening factor out the window. Drawing a lot more power to get a lower sq and small gain. Needs greater electrical and its higher risk. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
AstoSoup Posted October 21, 2014 Report Share Posted October 21, 2014 Yes but he was ask g if he wired 2 pairs of subs down to one then connects both to the amp if it will work. That would give him a .5ohm load. Maybe the amp can or can't handle that. Best way to find out is try. However I isn't recommended. At that point your throwing the dampening factor out the window. Drawing a lot more power to get a lower sq and small gain. Needs greater electrical and its higher risk. If it's a mono amp, it's as simple as wiring as in the diagram I linked above. That would give him a 2ohm load, rather than a .5ohm. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else. Link to comment Share on other sites More sharing options...
