Miguels Posted February 28, 2015 Report Share Posted February 28, 2015 (edited) Migules you don't get more rise if you have 2. Ohms of box rise it's 2 ohms period So at .5 ohms you will rise to 2.5 ohms at 2 ohms you would rise to 4 ohms still 2 ohm rise now I think it's a loaded question cause I need to know what amp a does at 2 ohms and what amp b does at 4 ohms they could be very different As it sits a 1000 watts is a 1000 watts at .5 ohms or 2 ohms or he'll even 8 ohms the only difference would be .5 draws more current and makes more heat then the 2. Ohm amp okay.. you just made my point.. you rise to 2 omhs not to 4 ohms.. do amps make more power at 2 ohms or 4ohms? smh One makes 1,000 Watts into 2 Ohms. One makes 1,000 Watts into .5 Ohms. You have four DVC 4 Ohm woofers. Which amp will play louder with these woofers? Why? Guess #1: The one that you can wire to .5 because of rise. You will get more output across the frequency spectrum. As different frequencies are played the enclosure (well, most, right Kyle?..... too early? :cheers: ) the impedance will change with the dynamics of music. If you are starting lower, it takes longer to climb. Guess#2: Is the amp that makes 1k @ 2 ohms stable at .5? If so, that one, wired to .5 thank you.... i seen people rise to 1.2 when wired to .5 ohm..... same amp and subs wired at 2 ohms and they get rise at 8 ohms why would the amp matter about rise? because in the real world you get impedance rise by the way it was tones not music.. music could rise even more also it depends on amp.. what wattage does it do at higher loads. Edited February 28, 2015 by Miguels Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Kyblack76 Posted February 28, 2015 Report Share Posted February 28, 2015 Migules you don't get more rise if you have 2. Ohms of box rise it's 2 ohms period So at .5 ohms you will rise to 2.5 ohms at 2 ohms you would rise to 4 ohms still 2 ohm rise now I think it's a loaded question cause I need to know what amp a does at 2 ohms and what amp b does at 4 ohms they could be very different As it sits a 1000 watts is a 1000 watts at .5 ohms or 2 ohms or he'll even 8 ohms the only difference would be .5 draws more current and makes more heat then the 2. Ohm amp okay.. you just made my point.. you rise to 2 omhs not to 4 ohms.. do amps make more power at 2 ohms or 4ohms? smh One makes 1,000 Watts into 2 Ohms. One makes 1,000 Watts into .5 Ohms. You have four DVC 4 Ohm woofers. Which amp will play louder with these woofers? Why? Guess #1: The one that you can wire to .5 because of rise. You will get more output across the frequency spectrum. As different frequencies are played the enclosure (well, most, right Kyle?..... too early? :cheers: ) the impedance will change with the dynamics of music. If you are starting lower, it takes longer to climb. Guess#2: Is the amp that makes 1k @ 2 ohms stable at .5? If so, that one, wired to .5 thank you.... i seen people rise to 1.2 when wired to .5 ohm..... same amp and subs wired at 2 ohms and they get rise at 8 ohms why would the amp matter about rise? If your "rise" did shit... then you had a window down.. or .. a door open.. or somthing..... the amp has ZERO to do about anything Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted February 28, 2015 Report Share Posted February 28, 2015 Migules you don't get more rise if you have 2. Ohms of box rise it's 2 ohms period So at .5 ohms you will rise to 2.5 ohms at 2 ohms you would rise to 4 ohms still 2 ohm rise now I think it's a loaded question cause I need to know what amp a does at 2 ohms and what amp b does at 4 ohms they could be very different As it sits a 1000 watts is a 1000 watts at .5 ohms or 2 ohms or he'll even 8 ohms the only difference would be .5 draws more current and makes more heat then the 2. Ohm amp okay.. you just made my point.. you rise to 2 omhs not to 4 ohms.. do amps make more power at 2 ohms or 4ohms? smh One makes 1,000 Watts into 2 Ohms. One makes 1,000 Watts into .5 Ohms. You have four DVC 4 Ohm woofers. Which amp will play louder with these woofers? Why? Guess #1: The one that you can wire to .5 because of rise. You will get more output across the frequency spectrum. As different frequencies are played the enclosure (well, most, right Kyle?..... too early? :cheers: ) the impedance will change with the dynamics of music. If you are starting lower, it takes longer to climb. Guess#2: Is the amp that makes 1k @ 2 ohms stable at .5? If so, that one, wired to .5 thank you.... i seen people rise to 1.2 when wired to .5 ohm..... same amp and subs wired at 2 ohms and they get rise at 8 ohms why would the amp matter about rise? I think he means when all else was equal, and just the wiring configuration was different. Or at least thats how I take it. Quote Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
Kyblack76 Posted February 28, 2015 Report Share Posted February 28, 2015 Migules you don't get more rise if you have 2. Ohms of box rise it's 2 ohms period So at .5 ohms you will rise to 2.5 ohms at 2 ohms you would rise to 4 ohms still 2 ohm rise now I think it's a loaded question cause I need to know what amp a does at 2 ohms and what amp b does at 4 ohms they could be very different As it sits a 1000 watts is a 1000 watts at .5 ohms or 2 ohms or he'll even 8 ohms the only difference would be .5 draws more current and makes more heat then the 2. Ohm amp okay.. you just made my point.. you rise to 2 omhs not to 4 ohms.. do amps make more power at 2 ohms or 4ohms? smh One makes 1,000 Watts into 2 Ohms. One makes 1,000 Watts into .5 Ohms. You have four DVC 4 Ohm woofers. Which amp will play louder with these woofers? Why? Guess #1: The one that you can wire to .5 because of rise. You will get more output across the frequency spectrum. As different frequencies are played the enclosure (well, most, right Kyle?..... too early? :cheers: ) the impedance will change with the dynamics of music. If you are starting lower, it takes longer to climb. Guess#2: Is the amp that makes 1k @ 2 ohms stable at .5? If so, that one, wired to .5 thank you.... i seen people rise to 1.2 when wired to .5 ohm..... same amp and subs wired at 2 ohms and they get rise at 8 ohms why would the amp matter about rise? I think he means when all else was equal, and just the wiring configuration was different. Or at least thats how I take it. Well.... if your wire to .25, and rise to 1 if you wire to 1 and rise to 4.... ?????? Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ROLEXrifleman Posted February 28, 2015 Report Share Posted February 28, 2015 Wiring series-parallel/parallel-parallel makes no difference, yes it does 3 Quote Rolex you sicken me. Just let me finish my pie ~ Juice Link to comment Share on other sites More sharing options...
Miguels Posted February 28, 2015 Report Share Posted February 28, 2015 also the subs at .5 would be parallel and at 2 ohms they will be in series/parallel.. didn't they test this and wiring parallel was louder? Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted February 28, 2015 Report Share Posted February 28, 2015 OMFG......bwahahahahahha Please Read the Question guys!!!!!!!!! 2 amps, 4 subs, one makes 1k w @.5 ohms, one makes 1 k w @2 ohms Which amp is capable of getting the loudest!!!!!!!!!!!!!!!!! But that isn't a given. He didn't say the amps were identical, therefore we don't know for a fact that the one that does 1k @ 2 ohms is stable at .5, but if it is, and the subs can handle that power, then yes. Quote Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
Miguels Posted February 28, 2015 Report Share Posted February 28, 2015 Migules you don't get more rise if you have 2. Ohms of box rise it's 2 ohms period So at .5 ohms you will rise to 2.5 ohms at 2 ohms you would rise to 4 ohms still 2 ohm rise now I think it's a loaded question cause I need to know what amp a does at 2 ohms and what amp b does at 4 ohms they could be very different As it sits a 1000 watts is a 1000 watts at .5 ohms or 2 ohms or he'll even 8 ohms the only difference would be .5 draws more current and makes more heat then the 2. Ohm amp okay.. you just made my point.. you rise to 2 omhs not to 4 ohms.. do amps make more power at 2 ohms or 4ohms? smh One makes 1,000 Watts into 2 Ohms. One makes 1,000 Watts into .5 Ohms. You have four DVC 4 Ohm woofers. Which amp will play louder with these woofers? Why? Guess #1: The one that you can wire to .5 because of rise. You will get more output across the frequency spectrum. As different frequencies are played the enclosure (well, most, right Kyle?..... too early? :cheers: ) the impedance will change with the dynamics of music. If you are starting lower, it takes longer to climb. Guess#2: Is the amp that makes 1k @ 2 ohms stable at .5? If so, that one, wired to .5 thank you.... i seen people rise to 1.2 when wired to .5 ohm..... same amp and subs wired at 2 ohms and they get rise at 8 ohms why would the amp matter about rise? I think he means when all else was equal, and just the wiring configuration was different. Or at least thats how I take it. Well.... if your wire to .25, and rise to 1 if you wire to 1 and rise to 4.... ?????? amp rising to 1 ohm will have more output than if it rises to 4 ohms Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Kyblack76 Posted February 28, 2015 Report Share Posted February 28, 2015 run a sig generator... for real..... You are wired at 2ohm, and you see 8ohm.. well fuck.. at a certain FREQ ?!??! fuck ya... youll see 8 ohm even on my rig i saw 14ohm....... on SOME freq's and pulls.... hell.. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ROLEXrifleman Posted February 28, 2015 Report Share Posted February 28, 2015 Wiring series-parallel/parallel-parallel makes no difference, yes it does Let me expand on this. While it series parallel doesnt effect the output of the amplifier, since the amplifier produces wattage based on the load presented, the woofers due to teh way they are wired will process the wattage diffrently 2 Quote Rolex you sicken me. Just let me finish my pie ~ Juice Link to comment Share on other sites More sharing options...
