Chris Hammer Posted April 4, 2015 Report Share Posted April 4, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2c MY BUILD *****http://tinyurl.com/gmcbuild***** Vehicles 2005 GMC Canyon CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.) crf250r - Used to be race bike..now I just trail ride..practice at the track on it. CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg Sold to: Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585 Shower farts still piss me off.I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot. Link to comment Share on other sites More sharing options...
plugdumps Posted April 4, 2015 Author Report Share Posted April 4, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2c After messing with google sketchup i can get about an inch between pole vent and the back of the box. Im just now thinking of running the 2 sa 10's. But i can only squeeze 25 for port area max. And thats port firing up. So the dimensions of it change since the box is a wedge Link to comment Share on other sites More sharing options...
Joe X Posted April 4, 2015 Report Share Posted April 4, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2c After messing with google sketchup i can get about an inch between pole vent and the back of the box. Im just now thinking of running the 2 sa 10's. But i can only squeeze 25 for port area max. And thats port firing up. So the dimensions of it change since the box is a wedge A single 6" areo will wotk on two of those, a couple of 4" aeros as well, tuning around mid 30s. Link to comment Share on other sites More sharing options...
plugdumps Posted April 4, 2015 Author Report Share Posted April 4, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2cAfter messing with google sketchup i can get about an inch between pole vent and the back of the box. Im just now thinking of running the 2 sa 10's. But i can only squeeze 25 for port area max. And thats port firing up. So the dimensions of it change since the box is a wedge A single 6" areo will wotk on two of those, a couple of 4" aeros as well, tuning around mid 30s. Single 6" for 2 sa 10's? Only prob is the aero would be firing at b pillar wal and would not have 6" between wall and port dont even think 2 4"'s would have 4" Link to comment Share on other sites More sharing options...
khinds94 Posted April 4, 2015 Report Share Posted April 4, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2cAfter messing with google sketchup i can get about an inch between pole vent and the back of the box. Im just now thinking of running the 2 sa 10's. But i can only squeeze 25 for port area max. And thats port firing up. So the dimensions of it change since the box is a wedge A single 6" areo will wotk on two of those, a couple of 4" aeros as well, tuning around mid 30s. Single 6" for 2 sa 10's? Only prob is the aero would be firing at b pillar wal and would not have 6" between wall and port dont even think 2 4"'s would have 4" How much space do you have? I have found d that with a 4 inch port having 2-3 inches works better than having it 4 inches from the wall 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt Link to comment Share on other sites More sharing options...
plugdumps Posted April 5, 2015 Author Report Share Posted April 5, 2015 You don't need 1" behind a pole vent. The space needed for them is determined by the size of the vent itself. Air is a fluid and you have to think how it will flow in and out of that vent. 1"diameter vent I bet 1/2" of space to the back wall will not restrict it one bit. Just my 2cAfter messing with google sketchup i can get about an inch between pole vent and the back of the box. Im just now thinking of running the 2 sa 10's. But i can only squeeze 25 for port area max. And thats port firing up. So the dimensions of it change since the box is a wedge A single 6" areo will wotk on two of those, a couple of 4" aeros as well, tuning around mid 30s. Single 6" for 2 sa 10's? Only prob is the aero would be firing at b pillar wal and would not have 6" between wall and port dont even think 2 4"'s would have 4"How much space do you have? I have found d that with a 4 inch port having 2-3 inches works better than having it 4 inches from the wall i can do 2-3 haha thats like it tho Link to comment Share on other sites More sharing options...
