Miguels Posted March 30, 2015 Report Share Posted March 30, 2015 what sup fellas im looking to going for a 3 way setup in my car. im looking ant getting the hertz HSK 163 the option will be 2 3 inch and 2 tweeters the pillar and 1 6.5 on the door maybe 2. the amps are the sax200.4 and sax125.2 for the pillars. i know i can us the crossover but rather not and just get the 3sixty.3 to control every channel my question comes here. how do i wire 8 channels of speakers on 6 channels from the amps? i want to keep rear speaker to avoid having a huge rear deck empty my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
bigmizzle99 Posted March 30, 2015 Report Share Posted March 30, 2015 If the speakers are 2ohm capable then you could parallel 2 on each side (assuming they are 4 ohm to start). Not many are. Camaro SS Build Altima build 2.0 Altima build 1.0 Link to comment Share on other sites More sharing options...
Miguels Posted March 30, 2015 Author Report Share Posted March 30, 2015 i know that.. what im trying to see is how do people wire the extra 2 speakers being 2 channels short on amplification my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
SIDE SHOW Posted March 30, 2015 Report Share Posted March 30, 2015 Can you run the rears off headunit power (the rear speakers will more than likely bring your sound quality down) Link to comment Share on other sites More sharing options...
Miguels Posted March 30, 2015 Author Report Share Posted March 30, 2015 my head unit has channel gain and is rta capable my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
OrionStang Posted March 30, 2015 Report Share Posted March 30, 2015 You need another amp. Also keep in mind that the 3" is the weak link in the Hertz set, does not like to be overpowered or crossed too low. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
hoit Posted March 30, 2015 Report Share Posted March 30, 2015 you probably could run the back off of deck power...but why? I've only been told that rear fill only takes away from your front stage. you've got plenty of power....i'm with you on finding the answers though. 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
Miguels Posted March 30, 2015 Author Report Share Posted March 30, 2015 You need another amp. Also keep in mind that the 3" is the weak link in the Hertz set, does not like to be overpowered or crossed too low. really? wtf. those are the ones i really wanted.. what about the mille series my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
OrionStang Posted March 30, 2015 Report Share Posted March 30, 2015 The thing is, they don't take much to get loud. I have an idea for you, give me a sec. SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
OrionStang Posted March 30, 2015 Report Share Posted March 30, 2015 Off the 200.4, front channels to comp crossovers with 3s and tweets only hooked to it (This will split the power between drivers). Rear channels directly to 6.5s. Then use the 125.2 for your rear fill. I know you said you don't want to use the crossovers, but this is the best way I think. Fuck deck power. No subs on this setup? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
