TaylorFade Posted April 14, 2015 Report Share Posted April 14, 2015 Since I was bench testing the Banda ICE 4000, I decided to pit it against some similarly sized amps. In case you missed the bench test you can review that here...http://www.stevemeadedesigns.com/board/topic/197283-my-test-banda-ice-4000/I call this test "max useable" because all I do it set them for max clean and then turn them up until they stop gaining on the meter. I record the clamp and score at the highest point regardless of clipping or distortion. Fluke meters were used for the clamping. I purposely did not use the AMM-1. Output numbers are sort of irrelevant here so they are rounded to the nearest 100w. I really only clamped to monitor things in case there was an anomaly and to verify reactives were similar between the amps.Voltage drop is not recorded but all amps were given the same starting voltage of 14.5v on a large bank of caps.(3) beefy 3" coils in a daily setup were used so that thermal issues were kept at a minimum. The frequency used was 50hz.Each amp was wired to .66 nominal and each amp had similar rise to 2.4 ohms.Banda ICE 4000- 152.1dB- 2,900vaTaramps HD4000- 152.1dB- 2,900vaTwisted Sounds 3.5k- 151.6dB- 2,600vaMMATS 4000- 151.3dB- 2,200va Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted April 14, 2015 Report Share Posted April 14, 2015 Very interesting. From a real-world performance standpoint the Brazilian amps don't look too bad. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
MrSkippyJ Posted April 14, 2015 Report Share Posted April 14, 2015 so this is more of a burp useable test than a daily useable test? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Lbox88 Posted April 14, 2015 Report Share Posted April 14, 2015 Very interesting. From a real-world performance standpoint the Brazilian amps don't look too bad. Sure, as long as you're ok with keeping a couple fire extinguishers nearby at all times. UBL | Build Log Link to comment Share on other sites More sharing options...
Keith77 Posted April 14, 2015 Report Share Posted April 14, 2015 Im a little surprised at the MMAts Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle. Link to comment Share on other sites More sharing options...
n8ball2013 Posted April 14, 2015 Report Share Posted April 14, 2015 The only thing that surprises me is that they are claiming American made THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
CleanSierra Posted April 14, 2015 Report Share Posted April 14, 2015 As always, thank you for taking the time and testing. I can't wait for all of the 18-24 year old guys who hug the SHIT out of the Brazilian amps to see these results and say "SEEEEEEEE, I told you they kicked the shit out of Korean 'junk' amps!". It's coming, mark my words. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
hoit Posted April 14, 2015 Report Share Posted April 14, 2015 tuned! 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
kremer90 Posted April 14, 2015 Report Share Posted April 14, 2015 As always, thank you for taking the time and testing. I can't wait for all of the 18-24 year old guys who hug the SHIT out of the Brazilian amps to see these results and say "SEEEEEEEE, I told you they kicked the shit out of Korean 'junk' amps!". It's coming, mark my words. ^hes right you know. 4 Shok triton 15s walled in 2000 Mirage 2 aq3500s (only 1 currently) 2 XS xp950s/ 2 XS xp3000s 220a alt (waiting to be installed) Best score to date: 152.2 @ 31hz 150.0 @ 26hz Link to comment Share on other sites More sharing options...
TaylorFade Posted April 16, 2015 Author Report Share Posted April 16, 2015 so this is more of a burp useable test than a daily useable test? Not necessarily. More power is more power. And one of the claims made by the Brazilian camp is that rise doesn't affect them as much as Koreans. This test kind of confirms that. I mean... half a dB isn't really anything to write home about in a daily, but that's an ass whippin in the lanes. It's just another data point. It's not an end all, be all test that will settle any debates. Link to comment Share on other sites More sharing options...
