Frustrating alt whine won't go away...
check out this vid on youtube for this problem
I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping...
Did you used a multimeter on the ground points yet for the amp?
to see if the ground is in the 20's or below that
  • Replies 112
  • Created
  • Last Reply
No. For continuity?
No. For continuity?
nope on impedence on the multimeter negative test lead to the negative post on the battery then a long jumper test lead from the positive on the multimeter to the grounding point where the amp is grounding at for this test
Possible pinched wires maybe? That has happened to me before on pinched wires under a seat and once i moved it went away. could also be pinched rca somewhere.
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
I recently had a isue with a amp and took it out and it stopped its also changed noises when i moved it a lot and the rca inputs were bad on it.
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
1
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
tripple post :/ :fool:
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
No. For continuity?
Ok, I'll check the grounds for impedence...since I have rear batt, should I also front battery neg to rear battery neg?
I don't think this is it, I just re-ran new RCAs and the path is pretty a clean shot to the amp aside from the few extra inches at the end.
No. For continuity?
what are the numbers when you check it?
  • Who's Online   1 Member, 0 Anonymous, 361 Guests (See full list)
