Sign in to follow this
CarAudioFab
How to - Crimp Heavy Lugs and Wire Ferrule Connections
In our latest video I show a quick few pointers for making some great connections to our wires that can be used on power supply and ground wires. Although soldering is a great alternative to using a hydraulic crimper for making lug to wire connections it does take time to do correctly. A hydraulic crimper actually creates a “cold weld” securing the wire within the lug terminal.
In this video I also show the use of wire ferrules. These help secure the wire within amplifiers or other gear that has set screw style terminals. The advantage is they help prevent stray wire strands from shorting out between the terminal block inputs. This is especially helpful for amplifiers that do have power and ground connections close to one another.
I hope this video helps give you some ideas for some really clean wiring techniques. Thanks for watching!
  • Like (+1 Rep) 10
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
Share this post
Link to post
I have got to get me one of those techflex cutters
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Share this post
Link to post
Could I use thin walled copper tubing to make my own ferrules??
Edited by 81000D
Share this post
Link to post
I suppose you "could" but I would think you would have trouble finding a perfect diameter, it may corrode easier, and ferrules are honestly so cheap I don't think its worth the effort.
Edited by CarAudioFab
-Mark
Share this post
Link to post
