Testing amps on alt
How do I test my alt amp output.
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
  • Replies 110
  • Created
  • Last Reply
With the alt Loaded down with a clamp meter on the positive from the alt.
I have a nice attachment for my fluke.
You will also need a clamp that reads DC. Most DO ONLY AC. Keep that in mind.
Heres a vid of my clamp attachment,... fucking love this thing. It has a 15' cord, so i can monitor inside the cab, live time.
and, on music..... which, is killer....
not trying to thread jack, but Kyle how did you get the alts to alternate like that with the different voltages or were they built like that? just curious
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
"not trying to thread jack, but Kyle how did you get the alts to alternate like that with the different voltages or were they built like that? just curious"
Ok.... it took me a few minutes to get it myself.
In this application your seeing, i have a 350, and a 270.
I have a VCM. The vcm cant control both. The internal on the 270 is set at 14.8.
VCM is on the 350. WIth no draw, or very little, i could manipulate what would turn on buy "adjusting the voltage" on the vcm.
If i turned it ABOVE 14.8, the 350 would do the work, because the internal on the 270 is set at 14.8. If i turned it LOWER, the 270 would "pick up" to regulate to 14.8.
This would not matter when i let it eat, because id dip to around 13 or below, or whatever, and BOTH WOULD TURN ON to pick up .... Make sense?
Ive since not cared for the vcm, ditched it, and just use a simple turn on, on both alts......
K I S S
Keep it simple stupid
His probably getting readings from alt battery and amps. Voltage is never the same.
i could manipulate what would turn on, with that vcm. The 270 being internal reg, i could "play" with the turn ons on each..... again, when, the system was up and running, and voltage dipped below, both would turn on, and do their thing........
i ditched the vcm, and just went easy peasy....
Okay I just ordered a clamp meter, I still seem to be getting bad voltage drops all the way down to 11.7 and amp gain 60% on deck 0. From alt to amp I get about a .7 drop. The belt is Tight, alt dual set up is a dc270 only running to the amp xdi2000 arc audio,
what clamp ? link me
also.. is this at idle ? Your alt may not make shit at idle....... rev it up.
Im just spit balling...
  • Who's Online   0 Members, 1 Anonymous, 365 Guests (See full list)
