Mechman Alternators
Engine temp hotter with new mechman 320 billet unit....
I gotmy mechman 320 billettech unit into my 84 ford mustang with a 92 5.0 engine and wired it all up,works great stereo hitting pretty hard, havent dropped the real amp in yet (5k). I have noticed since the install the engine temp seems to run hotter on the gauge and creeps up even more when bassing hard for longer periods of time.
wondering if this is normal? the car has not overheated or anything it just used to run around 1/3 on the gauge now it gets up over halfway. the radiator hose runs right across the top of the alternator and i do have some heat wrap around it there
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
If it is a stock gauge then the calibration might be off, i would use a quality temp gauge that has actual temp numbers on it.
The stock gauge could move a lot with just a minor temp increase, and unless you know where each mark on your gauge is at temp wise you would only be guessing what temp your actually running.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
think i may buy one of those radiator caps with the temp guage on it and see what it reads at
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
id rather not change any gauges or bolt anything in the car really.
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Something crazy but maybe your stock alt wasn't putting out enough juice to power some of the gauges correctly.. just a thought
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
Granite Crystal Metallic Exterior
Inferno Red Interior
5.7 HEMI AWD
LMI Air Hammer Intake
Corsa exhaust
Custom Tune
now im running at 14.5 volts instread of 14.0 maybe that has something to do with it?
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
The engine is working harder to drive the alternator. It will heat up a little more, but shouldn't get past the thermostat temp. If it's a tuned engine, additional cooling upgrades might be required
-Nick
really? holy shit then i should remove mine
its going to work a bit harder but nothing noticeable. 15hp at best and that includes from the stock so maybe 5hp more than stock. the alt is not the issue. could be that you pay more attention to the gauges now that the new alt is in. or could be that the thermostat and water pump are giving out and you are thinking thats the cause.. im running the 370a and notice no cooling difference. heck, there are guys here with 2 alts even some with 4 and they have no cooling issues
  • Who's Online   0 Members, 0 Anonymous, 1693 Guests (See full list)
