XS Power
Would I be better off adding this as a second battery in addition to my stock factory battery or replacing my factory battery with this d3400?
Also, what is the benefit of getting the billet mounting tray? To better secure the battery?
Do I need side post adapters ? Any other post or fittings?
Thanks!
Current Setup:
Mechman 370a Alt 4 pin
DC Triple Alt Bracket
XS3400 Battery
4 Ampere 6.5 components 4 tweets
Ampere 150.4 way
Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms
DG Roll Pan
LED License Plate Lights
If one battery is the only thing in your budget then I'd run the D3400 off the system by itself and let the stock battery run the regular electrical for your vehicle. Don't tie them together though with them being different makes and models. You would only do this if you had 2 batteries that were exactly the same.
It's perfectly ok to tie them together. Plus they would have to both be tied together to charge off the alt.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
So im thinking of just adding the 3400 in addition to stock battery according to the post so far. Do the batteries come with the necessary gauge wire or is that purchased sepratey?
Current Setup:
XS3400 Battery
Ampere 150.4 way
DG Roll Pan
  • 3 weeks later...
If purchasing a D3400 they come with m6 bolts for various ring terminals. if you are replacing the factory battery, I would suggest the 551 side post adapters for gm vehicles. If you are adding a D3400 as a secondary, the required accessories or wire would be dependent on how you mount and run the battery cables which are sold separate.
