Sq help please
g2shuck
Ok so withour time alignment am I better off to try to keep them close to the mid in the door panel or am I not understanding rhat correctly?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I'm saying you have to test and tune. Test in multiple locations and see what works and what doesn't.
No one can tell you exactly where to place your tweeters and work perfect.
I'm just trying to help with the limitations of the component set theory ... and this challenge may be more difficult running at 2 ohms ...
Ok test and tune it is then. Thank you for all the help and explanation.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Use a tape measure to get the distance from the passenger midbass driver to the listener's right ear. The distance to the tweeter should be exactly the same.
The angles can be different but the measuring distance should be the same. This way, you should only need 2 channels of time alignment instead of 4.
Calculate the difference from the left side and offset until you have a great center point when the singer sounds prominent on the center on top of the hood of the vehicle.
That should be enought to get you bit bu the SQ bug ... LOL
  • Who's Online   0 Members, 1 Anonymous, 882 Guests (See full list)
