Time to run some wire.
8330BFC8-8EB6-435F-81B7-742F1D3AD16D_zps
Going to run 3 power and 1 ground for now, I plan to add 2 more ground runs under the car later on as I add power. Only 2 of the postives will be used for now, the extra is just to have options later on.
A6E5D043-3657-4860-8A10-08772EFE8466_zps
Sorting things out.
33ECC85E-7A82-4BDF-B41A-4B1A96B5F7F7_zps
7A50F2C9-BD34-4BD5-8B9A-D50B93021F58_zps
Also sealing up the first layer just because. 2nd layer will fit much closer but I like to overkill where I can.
D7F81F89-5831-4E60-9EDF-EDCA2B5BC50C_zps
Also upgraded the mirrors on the Jeep to the later model style, they are larger and also are positioned better. That way I can see behind me as well as possible.
94D15C39-F5A5-486D-B91C-242E46F2FDA1_zps
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
Getting ready to install the 2nd layer in the wall shell.
0914065A-7081-44FB-9559-E1B7719D4110_zps
Going a little over kill but I want these panels to adhere well. The plan is to use lots of screws and glue.
1) Make a grid to drill pilot holes all the way though the wood.
2) Counter sink to give the wood filler something to grab on to and sink the screw heads.
3) Spread lots of glue on the back side.
4) Install the panel and start screwing from the center outwards in all directions to spread the glue and push out the air pockets.
5) The pilot holes allow to air and excess glue to escape as the sheet gets pressed down, the excess glue is then cleaned up.
976EDC01-ACA8-4E07-A747-20944206F90F_zps
B441E48F-3D24-46FD-8870-E33109450D96_zps
E3834AE0-B4AF-434E-B9DA-0D648473A74B_zps
After 9 hours, a half gallon of glue, and 6lbs of screws, the shell is double layered and super solid. Arms are sore but I'm really happy with how it turned out.
40C28F1F-39D6-4596-ACBE-CF2630663FF0_zps
3FC5AA56-ECE1-4D0C-9309-A900044E012F_zps
Next thing to do is start sanding it all down, then start filling all the holes, then sand, then fill, then sand, then paint or resin, have not deiced yet, I do want to install the port first and go from there.
Wood filler and sanding
20E4C051-CC19-44AE-BC97-62A4F97D426F_zps
8DF49980-260D-489A-879C-11496F486442_zps
2E00E842-870B-44D4-A36B-DE0B734D021A_zps
New Window Tint
75703815-CB81-4723-B345-198F7E529858_zps
ADE82756-45E9-4834-9892-779C415111A0_zps
8389E345-14EA-453B-B877-25BE43B9BAFA_zps
511758F2-A96F-4495-AD52-5F27BC814415_zps
Getting some of the interior back in, will be doing something to clean things up back here.
4D851CFD-F52D-4A1C-8B08-F2EBD70ABFDE_zps
  • Who's Online   0 Members, 0 Anonymous, 1125 Guests (See full list)
