CleanSierra Posted November 18, 2015 Report Share Posted November 18, 2015 How does the emf ermagerd do it with a 4" or a team sundown 12 4"? They don't make a 4" coil Team 12" sub, that's how. 1 Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted November 18, 2015 Report Share Posted November 18, 2015 (edited) Im feeling a little sceptical but the CJ guy says he can get me a frame, and recone hmmmGood luck getting enough spider to allow any excursion. I know you look to have changed your mind a bit which is a good thing.Just a quick FYI, the Level 6 coil is 3.5" in diameter. It doesn't leave you with much meat on a typical 9.25" spider. The new 6 spoke basket that Fi/Crossfire came out with will accommodate a 10" spider. Look for the Crossfire XSv2 12" in a blowthrough in the near future. Edited November 18, 2015 by CleanSierra 1 Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
catch 22 Posted November 18, 2015 Report Share Posted November 18, 2015 Didn't read the whole thread. Get the fi team 12 when it comes out 1 Quote Link to comment Share on other sites More sharing options...
CJ18 Posted November 18, 2015 Report Share Posted November 18, 2015 Im feeling a little sceptical but the CJ guy says he can get me a frame, and recone hmmmGood luck getting enough spider to allow any excursion. I know you look to have changed your mind a bit which is a good thing.Just a quick FYI, the Level 6 coil is 3.5" in diameter. It doesn't leave you with much meat on a typical 9.25" spider. The new 6 spoke basket that Fi/Crossfire came out with will accommodate a 10" spider. Look for the Crossfire XSv2 12" in a blowthrough in the near future. Incorrect. The Level 6 uses a 4" coil. To be built it would use a TC frame and 10" spider. Same spiders that are used on the 15" and 18" versions. Quote Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted November 18, 2015 Report Share Posted November 18, 2015 5 Quote When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL Link to comment Share on other sites More sharing options...
baron_of_bass Posted November 18, 2015 Report Share Posted November 18, 2015 My only issue is why are they willing to sell him something that clearly failed in the past? Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
mcfalcon Posted November 18, 2015 Report Share Posted November 18, 2015 I am not biased in any way. I nether like nor dislike DC. My question is similar to above. If it worked wouldn't DC be selling a level 6 12? Quote Still learning but have started gathering. Link to comment Share on other sites More sharing options...
CstrokerV Posted November 18, 2015 Report Share Posted November 18, 2015 i thought some one had success using one as a 12" awhile after orionstangs mishap... Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
CleanSierra Posted November 18, 2015 Report Share Posted November 18, 2015 (edited) Im feeling a little sceptical but the CJ guy says he can get me a frame, and recone hmmmGood luck getting enough spider to allow any excursion. I know you look to have changed your mind a bit which is a good thing.Just a quick FYI, the Level 6 coil is 3.5" in diameter. It doesn't leave you with much meat on a typical 9.25" spider. The new 6 spoke basket that Fi/Crossfire came out with will accommodate a 10" spider. Look for the Crossfire XSv2 12" in a blowthrough in the near future. Incorrect. The Level 6 uses a 4" coil. To be built it would use a TC frame and 10" spider. Same spiders that are used on the 15" and 18" versions.Oops, I was thinking of the Level 5. Can I see a tape measure on the Ti basket to show it's truly a 10" spider? My Crossfire C7 12s utilize the 4 spoke Ti basket and I've been told they are only 9.25" spiders. I know there is a reason that Roger won't put the big XS motor on my basket and that's because he said there isn't enough spider, hence the reason they tooled the new 6 spoke Ti basket with TRUE 10" landings. Edited November 18, 2015 by CleanSierra Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
will77530 Posted November 18, 2015 Report Share Posted November 18, 2015 Have fun with a Level 6 12, as far as I know it's only been done once and the results were less than stellar. It's been done before and like 88 said, the results weren't what you'd expect. If you want a sweet 12 that will work mechanically try using a sp4 12. I have a feeling you might be in for a headache of you make those 12 inch level 6s Level 6 is a turd anyway,...imho. cut its legs out from it, meh. So you want the level 6 motor (that isnt all that) on a smaller basket, smaller coil, smaller spider? sounds like a win. it wouldnt be a smaller coil or smaller spider but there is a reason lv6 12s arent made.... they dont fucking work 1 Quote Link to comment Share on other sites More sharing options...
