? On setting gain lower than amp can do
fordpride
Amp is a RF r500.1 with a birth of 635
Subs RF r2d2-12 x2 250 rms each
I have a DD-1 and my thinking is if I used the dd-1 it'll have my amp around 550-600 but I only want 400 going to my subs so is using a dmm my best option to set my amp ?
  • Replies 45
  • Created
  • Last Reply
I don't really want to. The box is built for p2's but budget got cut short with twins on the way. A friend that owns a local shop have me the r2's out of his display wall. So just trying to make it work without destroying them although that would be fun. Lol
i'm pretty sure your subs could handle 50-135 watts more even in a sealed box... i had my 4 12s in a sealed box with 500 rms over..........
also is there a way you can lower the sub output on your headunit??
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
well ok,,, here your options
1.Oscilloscopes or SMD Audio Multimeter AMM-1
2.just back the gain down a little bit
3.rewire your sub ohms
4.lower your sub output on your headunit (if your headunit has a dedicated sub rca)
  • Who's Online   0 Members, 0 Anonymous, 235 Guests (See full list)
