Actually I drive an SUV. So I am putting new P1683 6x8s in all four doors. And then use the 4 channel amp to power all 4 speakers. And if I feel like I need it later on, add a pair of Punch P1T-S Tweeters in the front doors.
My plan of action is:
Buy and install P1683 door speakers. (On the way)
Buy and install 0 gauge and distribution blocks.
Buy and install Prime 1200 watt amp. (To replace current amplifier)
Buy and install P3D4-12 subwoofers. (In current box)
Build new box for subwoofers.
Buy and install Prime 400 watt amp for door speakers.
Buy and install Punch P1T-S Tweeters. (Maybe)
Share this post
Link to post
I use KNU Krystal cables, they work great for me. Some people complain that the RCA ends fit too tightly on the terminals though so consider that in your analysis.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Share this post
Link to post
A tight connection is an issue...? Interesting.
Share this post
Link to post
I was looking for some 6 channel RCAs. Is Stinger a good brand for RCAs? They seem to be the only brand that carries 6 channel cables. Also, what about Rockford Fosgates RCAs?
Share this post
Link to post
Stinger is a good brand, for everything they make !
Don't buy too fancy ones. You don't need to spend an arm on rcas.
I use Knu, and Phonocar in my ride, I had Stinger ones in my old car.
Buy what you find locally : it's a good way to have local contacts ! The cheapest are not always the baddest...
Mazda CX-5
Pioneer AVH 5600 BT / SSA Evil 1 tweeters / SEAS Prestiige ER18 mids / mini dsp 2 x 4 / FI BTL N2 15" in 4ft3 @ 32 Hz / Incriminator Audio 20.1 and 3.4 / Zapco ST-2X / all 0 Ga OFC Knuconceptz wiring, rca's & accessories /  Optima group 34 under hood and Optima  Group 31 in the rear . SecondSkin Damplifier and Luxury Liner Pro on front doors, and cargo area.
Share this post
Link to post
There are not really any local shops in my area, so I am forced to go with online shopping. Alright, now down to the fuses..
How big (and how many) of fuses would I want for my potential system?
Share this post
Link to post
Rockford recommends a 150A for the r1200 and a 50A for the r400, also fuse the 0ga at the battery, a 250A would be fine there for this build.
Also see this video before ordering RCA cables, the Prime amps are single ended inputs.
Share this post
Link to post
