gizmo1 Posted March 11, 2016 Report Share Posted March 11, 2016 Well I ordered a level 3 15 from sonicelectronix about a month ago maybe 2 I got it everything was cool I went to order another and they didn't have m2's anymore only m2.1's So I ordered another m2 from droppinhertz. Well today I finally get the new 15 in and I notice the cone and surround are way different. On the 2 same motor and basket just different cone and surround. Will they still work well together or am I stuck with 2 subs I basically can't use? Quote Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 11, 2016 Report Share Posted March 11, 2016 Are the T/S parameters the same? Quote 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
reedal Posted March 11, 2016 Report Share Posted March 11, 2016 Do you have pictures of the subs that you can upload? It may help someone determine what sub you received and whether it is compatible/the same as your old sub. Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
magillaru Posted March 11, 2016 Report Share Posted March 11, 2016 Same thing with my fi teams. Two are older with a different surround and cone. As long as the specs, spider pack and leads are the same, you'll be fine. Quote Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
gizmo1 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Are the T/S parameters the same?Don't know both where supposed to be regulator old m2s. Neither came with spec sheets. Quote Link to comment Share on other sites More sharing options...
gizmo1 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Quote Link to comment Share on other sites More sharing options...
gizmo1 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Ignore the difference in dustcaps lol. So those are some super crappy cell pics I'll get some better ones up. The one with the patterns in the surround has a much beefier cone that makes the cone on the new sub look wimpy. Also can't tell from the pics really but the surrounds are also different in size and shape. Quote Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted March 11, 2016 Report Share Posted March 11, 2016 The one has the upgraded surround and stronger cone. It would make the ts parameters different, how much different I don't know. Quote That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
reedal Posted March 11, 2016 Report Share Posted March 11, 2016 Did you email droppinhz? Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
