Kyblack76 Posted March 31, 2016 Report Share Posted March 31, 2016 After a long drive time, or after a 9 hour show, my alts would spit out the smell of the powder coating, and fuck yes get warm.......... had i kept that build, i would have cut vents in the hood..... cant imagine the heat made from people running and hammering on quads.......... but electrical smell.. no...., mine was the coating, which, i gave zero fucks about, and would crack the hood when demoing for hours on end. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 31, 2016 Report Share Posted March 31, 2016 I second the double check. If its not toast now it will soon be. Call the mfg before it burns your car down. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Mosley_23 Posted March 31, 2016 Author Report Share Posted March 31, 2016 It might be the powder coating. It's not electrical. It's a weird smell. AND yes batteries were charged Link to comment Share on other sites More sharing options...
Masterbasser Posted March 31, 2016 Report Share Posted March 31, 2016 make sure ya read the insctructions that came with the alternator and follow everything on there, there is a reason for everything that is on the instruction sheet. i decided to ignroe 1 of the things and it messed mine up when i first got it. I had 2 ring terminals 1 of which was not the correct inner diameter on the charging stud and they arced together eventually melting the stud down. mechman was pretty cool and we split repair cost. Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl Link to comment Share on other sites More sharing options...
Ron36 Posted March 31, 2016 Report Share Posted March 31, 2016 Did u put a new belt on could be the belt skipping and making it smell. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
