03 corolla trunk build / Testing some sundowns, scores posted.
0157E4F3-8DA9-4AA4-BAFE-A15C71096473_zps
I think what you want is what is written on the lower right side
Edit: looking at the manual, it says to push that button to return to previous setting item for every mode. So that should be the correct button. The magnifying glass/ return arrow
My JVC was ok, just got rid of mine after a month and purchased a Kenwood last night. It was nice unit overall just didnt care for the navigation of the menu and its features.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
  • 9 months later...
I have decided to buy a term lab and waste my life testing things.
My Initial result with two 1500's at 1ohm each.
This setup is peaking at 38-39hz rolls off each direction. Doing about a 30 at 45hz, 28 at like 55hz
I removed the 90° and just put the end flare on and moved the box to the rear of the trunk. \
This is sub up and port to the side.
So, this made a big difference
edit: running one 1500 at .5 nets the same score as this
Today i made a new port, 4"X4" square and 28" long. So instead of being tuned to 39hz with 13sqin of port i am now at 16sq" tuned to 35hz
and now this is the high score. Still peaks around 38-39hz lol
  • Who's Online   0 Members, 0 Anonymous, 271 Guests (See full list)
