What size fuse for alternator power wire
you fuse for the wire... use ofc wire or welding wire. i have welding wire for all my power wires.
i understand that but i was told that you that you still need to fuse the power wire for the big 3. im buying sky high ofc but i dont know what fuse size i need
No reason to fuse it higher than what the alt can put out,
I'd use a 150 amp fuse.
If you fuse to high you defeat the whole purpose of having a fuse....
ok that makes sense. im also looking at buying a crescendo s1500.1 for my subs, but i dont know which specs i need to look at to calculate the fuse that i would need. is it the volts x amperes = watts to figure out the fuse size?
  • Who's Online   1 Member, 0 Anonymous, 1512 Guests (See full list)
