RageQuitForLife Posted May 14, 2016 Author Report Share Posted May 14, 2016 1 more post for the road:) Just fuse it for whatever the alt is rated for. If you have a 140 alt put a 140amp fuse on it. PERIOD this is not true. period. i know it's not exactly true. I'm just being sarcastic because this topic should be over. PERIODyou are part of the problem Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 14, 2016 Report Share Posted May 14, 2016 Correct me if I am wrong but we are talking about the cable that goes from the alt to the battery that is in the back of the car. There is no battery in the front. The batteries in the back have a separate fuse. Correct? If the cable gets pinched in the middle then the short will be energized from both ends to the short. The battery will start dumping power into it. The battery fuse will blow because it can supply the 250a to blow it. The alt also is dumping power into the short. If the alt can only supply 140a and the fuse is 250a then it won't blow because there is not enough power to blow it. Normally the fuse would be what the wire is rated for if . What we are doing here is not normal. Part of the confusion is that the 1/0 is bigger than what is needed as Strange Duck stated. The 1/0 will work but we have to take all things into consideration. 1/0 needed vs. wanted are two different things. This isn't a stock electrical setup. Having drop of 1-1.5v across a circuit as would be in stock limitations is really not desirable. Imagine you have a drop of 1.5v between your alternator and battery. You could be charging to 14v but still be discharging your battery at 12.5v. It'll hinder it's ability to recharge. While it may not be "needed" for safe operation of the equipment, it's certainly desirable from a performance standpoint As to the fuse issue... You can't use a fuse that will blow in the event of an alternator short circuit scenario but stay intact during normal day to day beatings. It doesn't exist. The reason you don't need to fuse the wire near the alt is because the second you turn the key off, there's no more flow of power. Problem solved. That's not the case with a battery, and hence why it needs to be fused ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted May 14, 2016 Report Share Posted May 14, 2016 Ok then don't fuse the alt. Make sure you turn the key off when you crash. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted May 14, 2016 Report Share Posted May 14, 2016 Most modern cars cut the power automatically in a crash. Should still be fused though. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
AB Xfl 12s Posted January 6, 2019 Report Share Posted January 6, 2019 On 5/7/2016 at 3:15 PM, RageQuitForLife said: anyone at all? 1500w amp should takea 120-150amp fuse. Generally 100rms watts/10amps. So (1500w) 15x10=150 Link to comment Share on other sites More sharing options...
