pumin Posted June 10, 2016 Report Share Posted June 10, 2016 Hi. Please advice amp/subwoofer for a daily listening system for my SUV and to match front speakers, I probably get only a pair of 6.5 inch, and a pair of tweeter. Music I listen to are 80% - extreme/death metal lots of kick drum, 10% - pop,jazz 10% - electronic/dubstep/rab/drum and bass. I aim for SQ, more musical, less distortion, deep, clean, and tight bass. Option 1: one SD-3 10" in sealed box. Option 2: two SD-3 10" in sealed box. Option 3: one SD-3 12" in sealed box. <-- preferred Option 4: two SD-3 12" in sealed box. <-- probably too much? Should I get them 4-ohm or 2-ohm version? and which amp? Please, for any other suggestions. Pumin Quote Link to comment Share on other sites More sharing options...
Smoove Posted June 10, 2016 Report Share Posted June 10, 2016 I have a SD-2 10. It's on a RF T5002 at 2ohm. been great Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
boom50cal Posted June 10, 2016 Report Share Posted June 10, 2016 single 10 or 12, on a Sundown SAE-600D. Keep it simple, keep it clean, keep it matching. Quote On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
Toby Ratcliffe Posted June 12, 2016 Report Share Posted June 12, 2016 Depending on the vehicle one SD-2 12" Dual 2 ohm wired in parallel to bring down to 1 ohm on a SAE-600D would be fine for what you want. Two SD-2 12" Dual 4 ohm all wired parallel would also see a 1 ohm load on a SAE-1000D and would give you a bit more low end. Budget and space is what will be the deciding factor. Quote Link to comment Share on other sites More sharing options...
DTS909 Posted June 12, 2016 Report Share Posted June 12, 2016 What they said. Lots of good amps that will get you the right amount of watts. The sd's sound great sealed and on rated power. Quote VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback Link to comment Share on other sites More sharing options...
pumin Posted June 12, 2016 Author Report Share Posted June 12, 2016 Thanks for all suggestions. If I go for 2 of SD3 subs, should I get 1500-watt amp (eg. SAE-1500D or SCV-1500D) instead of 1000-watt? Quote Link to comment Share on other sites More sharing options...
Toby Ratcliffe Posted June 14, 2016 Report Share Posted June 14, 2016 Thanks for all suggestions. If I go for 2 of SD3 subs, should I get 1500-watt amp (eg. SAE-1500D or SCV-1500D) instead of 1000-watt? If your budget will support it, that is what I would go with. The extra power will help in a sealed box. Quote Link to comment Share on other sites More sharing options...
DTS909 Posted June 14, 2016 Report Share Posted June 14, 2016 I vote the scv Quote VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback Link to comment Share on other sites More sharing options...
a1dookie Posted August 4, 2016 Report Share Posted August 4, 2016 I have two SD-3 10" with a crossfire C51700d amp in a sealed box. For the price it's amazing Quote Link to comment Share on other sites More sharing options...
bmxscion Posted August 18, 2016 Report Share Posted August 18, 2016 I have an SD-3 12" D4 in a sealed box just under 1 cu ft. The one I have was the prototype unit that has the machined outer spokes unlike the production models. I have it powered by a RF 501bd and processed with an MS-8. It is an awesome sub but I will be upgrading next year so I may sell this one. Quote Build Log Here: http://www.stevemeadedesigns.com/board/topic/161307-scion-xb-sundown-mechman-xs-power-rockford-fosgate-jbl-build-log/ You Tube Here: https://www.youtube.com/user/korndoggg31?feature=mhee Link to comment Share on other sites More sharing options...
