97burbalade Posted June 12, 2016 Report Share Posted June 12, 2016 I have 2 DC level 4 18 going into a Tahoe in a ported box, I have plenty of room but my question is how should box be designed and what's louder firing subs back and port back towards rear hatch or firing subs up and port up towards roof or subs up and port toward rear hatch Quote Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted June 12, 2016 Report Share Posted June 12, 2016 Sub up, port back is gonna be the loudest 95% of the time, with a single sub in a tahoe tho you could probably get away with both firing back and not make a huge difference. Just don't fire both port and sub up, it will sound horrible. Quote Link to comment Share on other sites More sharing options...
97burbalade Posted June 12, 2016 Author Report Share Posted June 12, 2016 Thanks wasteland audio and it's 2 subs , would you recommend a slot port in the center firing back or a slot port along bottom edge firing back and do you design boxes if so how much do you charge Quote Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted June 12, 2016 Report Share Posted June 12, 2016 whoops i thought it was only 1, my bad lol. I have 2 level 6 18s in my suburban and the box i built is a bottom slot port and it works pretty well. how far is it between the 2nd row and the hatch on a tahoe? i could figure something out for you, i don't charge lol Quote Link to comment Share on other sites More sharing options...
97burbalade Posted June 12, 2016 Author Report Share Posted June 12, 2016 48 inches between wheel wells 40 inches from back seat to rear door 24 inches tall I don't really what it much taller than that Quote Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted June 12, 2016 Report Share Posted June 12, 2016 Port length is 18.5". It's 49" wide but i know for sure it'll fit because that's how wide my box is. It comes out to 12.5cuft after displacement Quote Link to comment Share on other sites More sharing options...
97burbalade Posted June 13, 2016 Author Report Share Posted June 13, 2016 Thanks for the info. I ll start on it tomorrow. Do you by chance know what that box is tuned to? Quote Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted June 13, 2016 Report Share Posted June 13, 2016 No problem, and it's right around 32hz. make it a little longer if you want it lower. Quote Link to comment Share on other sites More sharing options...
97burbalade Posted September 19, 2016 Author Report Share Posted September 19, 2016 Hey I finally got started on box ran into a problem with the 49 inches it would not fit with factory plastic pieces in back had to trim to 48 inch will that change tune of box ? Quote Link to comment Share on other sites More sharing options...
Nightshade Posted September 20, 2016 Report Share Posted September 20, 2016 (edited) I am not sure about an SUV but subs up port up does not sound horrible in a hatchback. Actually it sounds pretty damn good and tends to get very loud in certain vehicles. A lot of Euro hatches do subs up port up and are super fucking loud!!! Anyway like I said I am not sure about doing both subs and port up in an SUV, but from personal experience sub up and port firing diagonal back into the corner of the hatch works very well for a single sub setup. The most recent SUV build that I did was a dual 15 box with a single 10" aeroport. The box was 5.5 cubes after displacement with 2 Crossfire XSPL V1 dual 1.4 ohm 15's. They were wired down to .35 ohms on a Sundown SCV3000D. The box was tuned to 47hz for SPL, however, would play over a 148 from 32-55hz. That is pretty damn cool if you ask me. It was an SPL box, but for some crazy reason was one of the absolute best sounding enclosures that I have ever built. Others that heard the box had no idea it was intended for SPL and not SQL. The best number that it put up was a 150.5 on the dash sealed with maybe 2200 watts after impedance rise. If we would have added more port area it would have probably helped to keep the rise down as well as increase the SPL due to more port area and the result of higher tuning. This more than likely would have killed any of the sound quality potential, and I say sound quality with the slightest amount of seriousness in my statement. If there is any interest in seeing the setup, it isn't pretty, let me know and I'll throw up a few pics that I snapped of it. It's not my build , but I did build the enclosure and do the box design. The setup is going to change to 2 Sundown ZV3 18's or quite possibly even 4 ZV3 18's ran off of a ton of power. The amplifier configuration isn't set in stone yet but will probably be a pair of Sundown SCV6000D's, SCV7500D's, or even a pair of NS2's when they are released. Edited September 20, 2016 by Nightshade Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz Link to comment Share on other sites More sharing options...
