As far as the relay goes, you just need one of these
http://www.parts-express.com/12-vdc-automotive-5-pin-relay-spdt-30-40a-bosch-type--330-073
If you want you can get a plug or just use crimp-on female disconnects. Plug:
http://www.parts-express.com/12-vdc-5-pin-relay-socket-interlocking-style--330-080
Here's a wiring diagram:
http://www.the12volt.com/relays/relaydiagram25.html
What I did on mine to help clean up the wiring is ran a busbar, like this:
http://spectrowireandcable.com/mm5/merchant.mvc?Screen=PROD&Store_Code=SpectroWireCable&Product_Code=9614&Category_Code=
I connected the large bolt on the busbar to the "30 pin", then connected all my amps/fans to the bus bar.
Build looks awesome so far though so keep up the work man. Can't wait to see more
Fosgate for the win!!!
For your first build, you got your shit together.... At first I thought this was another Steve build seeing all the Fosgate....
Tuned!
haha i try
Thanks! this helps a lot :good:
Love the car that you building bud, Im from South Africa and can relate to the golf MK2, im subscribed to this build for sure, cant wait to see the build progress.......... :yahoo: .................... :good:
This has to win SOTM when you're done ;)
Thanks! :good:
Got this in today
I now just need to find the information on how much cu ft the sealed section has to be for 4 zv4 15's
And then can start on ''drawing'' the plan for the wall..
It's going to be 3 cu.ft sealed per sub so 12 cu.ft sealed and around 22/24 cu.ft ported
With the port/tuning i'm going to be needing some help from you guy's but that's for later...
Did a (amateur) sketchup of the box/wall how it approximately will look like (ratio isn't well drawn)
Got a XS Power XE12-110 battery for up front instead of the Yellow top.
Don't know what to do with the Yellow top, keep it for the battery bank or sell it...
1771eeeb-9315-4ea4-b06d-0c53105dc195_zps
200A fuses for from the alternator to the XE12-110
And something to apply to the back windows so it's not see through because of the wall
