sbg Posted August 3, 2016 Report Share Posted August 3, 2016 So I just got a new high out put alt a few days ago. A 300 amp 6 phase large case hairpin, with built in voltage regulator set to 14.8v. I have 1 xs d3100, 1 batcap 2000 and a super start extreme agm. 1 run cca 1/0 from alt to batteries, 2 runs for each batt to the next. And I don't think I am holding as good of voltage as i should. Car is a 08 chevy hhr. 1 -18" FI sp4 2 synergy wfo 15.1 strapped at 1ohm, So each amp is seeing .5 Small Orion 250.2 on Orion loud speakers and soundqubed 4" tweets Kenwood DDx372bt . Ok so my stock alt was a 130 amp. I would drop to 11.7v at stops and parked and stay for the most part 12.3 12.4 at over 2000 rpm. Well I just got my alt and I am seeing mid 13s high 12s for the most part at over 3000rpm but still seeing low 12s at idle and some times 11s.Am I crazy to think with what I have That I should be holding high 13s and 14? I have checked my batteries all of them are good and rest at 12.9 all lugs on wires are still crimped on and don't move at all. No rust on grounds. And 2 of my grounds are on the factory grounding spot. I put a new gates belt on that was 1/2" shorter and is tight With no slip. What do you guys say I should change or try Or should I call them about the alt? Is it fine and I am just crazy thinking it should be better lol? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted August 3, 2016 Author Report Share Posted August 3, 2016 Don't mind my mess of wires. They are about to be all cleaned up 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
tboorn Posted August 4, 2016 Report Share Posted August 4, 2016 is the pulley on the new alternator larger (wider) or have more ribs than the stock one? it looks like it from the picture that the stock one has 4 ribs and the new alt has 5 ribs. and if thats the case and you dont have complete belt coverage that could be an issue, even if its not slipping. i would assume you couldnt switch to a wider belt because the pulley on the engine that controls it is still the smaller belt size. Fidelity Built to Last Team Sound Asleep 24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/ 2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3 2 DD M3b Maxwell 2.7V 3000F Supercapacitors Pioneer DEH-80prs Focal P165 V30 components Rockford Fosgate T-400.4 Link to comment Share on other sites More sharing options...
sbg Posted August 4, 2016 Author Report Share Posted August 4, 2016 is the pulley on the new alternator larger (wider) or have more ribs than the stock one? it looks like it from the picture that the stock one has 4 ribs and the new alt has 5 ribs. and if thats the case and you dont have complete belt coverage that could be an issue, even if its not slipping. i would assume you couldnt switch to a wider belt because the pulley on the engine that controls it is still the smaller belt size.HYes factory alt was 4 rib. New alt has wider and more ribs, I didn't think that would matter? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted August 4, 2016 Author Report Share Posted August 4, 2016 You can see the belt don't go all the way over. Short by 1 rib. I was thinking when I got it that the pullys were far off for each other. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
tboorn Posted August 4, 2016 Report Share Posted August 4, 2016 thats exaclty what i thought. youre alt can definitely suffer from that, without full belt coverage it may not get proper grip, im no alt expert but ive definitely heard them say you want the same pulley width, usually they will match it to your car. Fidelity Built to Last Team Sound Asleep 24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/ 2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3 2 DD M3b Maxwell 2.7V 3000F Supercapacitors Pioneer DEH-80prs Focal P165 V30 components Rockford Fosgate T-400.4 Link to comment Share on other sites More sharing options...
diegoclass2010 Posted August 4, 2016 Report Share Posted August 4, 2016 what rating do those amps have? are you available to a clamp meter to test out the alternator.... lastly you have a ground screwd in with screws by the battery... fix that! Link to comment Share on other sites More sharing options...
sbg Posted August 4, 2016 Author Report Share Posted August 4, 2016 what rating do those amps have? are you available to a clamp meter to test out the alternator.... lastly you have a ground screwd in with screws by the battery... fix that! I know the screwed down ground is not the best I just didn't have a bolt at the time. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted August 4, 2016 Author Report Share Posted August 4, 2016 what rating do those amps have? are you available to a clamp meter to test out the alternator.... lastly you have a ground screwd in with screws by the battery... fix that! I know the screwed down ground is not the best I just didn't have a bolt at the time. Think that was at 1ohm, I'm strapped at 1. So .5 each 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted August 4, 2016 Author Report Share Posted August 4, 2016 what rating do those amps have? are you available to a clamp meter to test out the alternator.... lastly you have a ground screwd in with screws by the battery... fix that! My clamp meter has dead batt:( 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
