sinister317 Posted August 4, 2016 Report Share Posted August 4, 2016 Just wanted to see if any of you have played around with these subs before. Was curious about their thermal capabilities. I have a pair right now and I want to power them with around 1500 clean watts. Just fishing to see if any beat on these subs before. Thanks. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted August 4, 2016 Report Share Posted August 4, 2016 Haven't beat on the t0 but I have on the t1. Did an install for someone running just under 1500 per. Was 2 12s. They took it fine but it would be pushing the limits of the t0. The t1 unlike the t0 has a copper heat sink that helps with thermal capabilities. I would go over 1200 on the t0 12. 1500 for a comp sure but no more then 1200 daily. If you know your pushing the limits and watch your volume you can push your luck at 1500watts but just know it could be risky t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
sinister317 Posted August 4, 2016 Author Report Share Posted August 4, 2016 (edited) Yeah the T0s 12s do 700 rms. I was actually going to give each sub like 750 to 800 clean watts. So if you think 1200 is good I should be fine lol. Edited August 4, 2016 by sinister317 Link to comment Share on other sites More sharing options...
dolarbilz Posted August 4, 2016 Report Share Posted August 4, 2016 (edited) 1200 will be fine so will 1500 you'll hear no audible difference , with little more power your wanting to give, you may just back the gains off a touch Edited August 4, 2016 by dolarbilz Link to comment Share on other sites More sharing options...
sinister317 Posted August 4, 2016 Author Report Share Posted August 4, 2016 Yeah I'm just trying to keep a lil overhead so the power stays clean. They look like they could take it. ? Link to comment Share on other sites More sharing options...
