4th order blow through sub question
fordpride
sealed. high qts/ low ebp, lower fs, softer suspension.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
2:1 is definitely on the smaller side, but should play pretty flat. If you have room to spare, Id use it.
LMFAO so true
:blush:
Inlighten me or a link please.
Here is the problem with ratios, they are a design shortcut and like all design shortcuts they make assumptions that can bite you in the ass if you don't know about them. Its not that ratios are always wrong, they aren't, the problem is they aren't always right.
Depending on the T/S parameters of a particular sub, one sub may give you a very flat and musical frequency response in a low ratio (say 2:1 or less) bandpass box, however a different sub could give you very peaky output and sound totally different in the exact same box. The other problem with ratios is they infer that making the rear chamber smaller has the same effect as making the front chamber larger, or vice-versa (both increase the ratio). However this is not the case and those two actions will have very different results.
Bandpass boxes are very tricky things compared to a regular ported box. Different people have different ways of designing them, with varied levels of success. To each their own. The way that works for me to is to size each chamber individually based on the parameters of the sub, the specs of the whole system, and what the desired performance is.
Builds:
If I understand that correctly you are saying take the parameters of the driver and design a sealed box then use those same parameters to design a ported box and put them together?
No.
What I'm saying is to take the T/S parameters and design a bandpass box with the proper sized sealed and ported chambers to do what you want it to do and don't worry about what the ratio is.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 1712 Guests (See full list)
