DD-1 Tuning With Spotify
Is there a certain way set gains if you use something like spotify? I typically always just use a usb for music, but spoitfy seems like a cool option. Is "full volume" on all phones a similar signal strength? Does anyone have input on this?
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
I use Spotify to listen to music. Rockford Fosgate has the 3sixty.3 tracks on there, which you can use with the dd-1. I play over Bluetooth, so I played the track, set my phone on full volume, and set my gains. My gain settings were different from when I was using the cd, but whether or not the signal is 100% clean, I don't know.
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I do know that phones will distort at different levels. Unfortunately, I can't say if the dd1 would even pickup a signal due to low voltage on the headphone out, but it's worth a try.
DD-1 picked up my pc sound card just fine (its good at full volume). So I just checked my phone on a track 2, and no signal was registered. Using a Galaxy s6 with known good source tracks.
Let me rephrase. I want to check if the dd1 will distort while using spotify through bluetooth on my 80prs. So voltage shouldn't be an issue, more of finding where it distorts. I'm going to try jhunts method with the rockford track on spotify. So far I've been running my system on my -5db dd1 disc tune and the subs have been fine. I appreicate the input though.
1999 Lexus GS 300
Pioneer DEH-80PRS
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds Tropo 6.5
