Not Your Grandfather's Ohm Load...
Charles Phillips
Hey! I'm trying to wire my SoundQubed Q1-1200.2 down to 0.5 Ohm. I have aftermarket watercooling going on it, so I'm not too worried about temps.
The problem is that I only have one HDS-312 Dual Voice Coil @ 2 Ohm each (currently wired down to 1 Ohm final load). Does this mean if I double the amount of wire joining the two coils, I can approach 0.5 final Ohm load?
Please don't just tell me not to do it. If any of us listened to that logic we wouldn't have the crazy setups that we do on here.
- 2009 Toyota Matrix Base -
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
- SoundQubed SQ-2200.2 x 2 -
  • Replies 46
  • Created
  • Last Reply
Nope, you're stuck with 1 or 4 ohms with that coil configuration.
Don't think adding wire would help, it would take away power from the VC's and just generate heat AFAIK.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
water cooling?
We're all friends here, you ain't gotta lie to kick it.
lol
that actually reminded me of an article in one of the old car audio mags back in the day. Some guy used a bunch of dental tubing and ran water cooled amps. Man i wished I still had those nags.
New build coming........
YouTube:http://www.youtube.c...6?feature=guide
Old Build Log: http://www.stevemead...d-on-the-cheap/
Old Screen name: Redrebel66
Based on the question you just asked I'd suggest sticking to the ohm load the amp is rated for.
Wiring below rated is best left to experienced users.
And no adding extra wires will not lower your ohm load,
Why you'd even think it would is beyond on me.
how would adding wire take power away? please explain.
I'd like to see thisbcustom watercooling. You don't run into that very often
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Poorly worded on my part, meant it would not allow all the power to be used by the coils instead would generate heat.
I'm just a dumb pipefitter who's not so good with all the word speak sometimes.
I'm guessing the watercooling is done via chillblocks or something
Haha I'm actually putting some PC water cooling equipment on it and running at 0.5 ohm when my HDC418s come in for the wall, just until I get the Q1-7000.
My logic was that more wire or heavier gauge = less resistance.
I wouldn't think that more wire would take away power from the voice coils. Having 2/0 wire creates less resistance than 1/0, so I wouldn't see why it would be any different.
- iPad 64GB -
- miniDSP 2x4 HD -
- PPI Art a200.2 -
u should really post some pics of thee water cooling equipment u got goin on it be interesting to see
06 Envoy
250a ALT
2x 2400 kinetiks
USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122
Taramp HD2500 for mid range
4xPioneer 6x9's 2x 1" Pioneer tweets
  • Who's Online   1 Member, 0 Anonymous, 333 Guests (See full list)
