OK. Let's go back to post 1 and look at Ohm's Law. If we're going to prove / disprove the hypothesis I've laid out, this is an excellent place to start.
I = E / R (see first post for what each stands for if you don't know already)
For the sake of simplicity, let's assume that we'd like to apply voltage to a 10,000 Ohm (10k) resistor and do the math on that. Let's consider the following voltages:
12.6V (nominal voltage of a fully charged battery)
I = 12.6V / 10,000 Ohms
I = .00126A
13.8V (healthy charging system)
I = 13.8V / 10,000 Ohms
I = .00138A
14.4V (optimistic)
I = 14.4V / 10,000 Ohms
I = .00144A
So, we can see that the formula does indeed support our hypothesis. So, now it's time to prove it - and that's the fun part.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
I = .00126A
I = .00138A
14.4V (optimistic)
I = .00144A
doesn't the resistor have to change to stay at 10,000 ohms at 14.4v versus at 12.6v?
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
It's been answered about 10 times already. Lol
Pioneer 80PRS
I = .00126A
I = .00138A
14.4V (optimistic)
I = .00144A
A resistor is a fixed variable. So, a 10,000 Ohm resistor is a 10,000 Ohm resistor as long as it's used within the design specifications. For example, you can't use a 1/2 watt resistor where you may need to dissipate 5 watts across it.
resistors oppose current flow not voltage. you'd have to use a substantial value of resistance to lower voltage. example would be using a resistor to get rid of amp turn on pop in Ford vehicles. to alter voltage with resistors you'd have to use it in a voltage dividing network type of scenario.
Edited by fasfocus00
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Long ago, I found this image in a textbook and used it in my presentations. Now, you can buy a t-shirt with it. Love it, and it's absolutely relevant here.
14572358_308015129575786_481446634272719
You will appreciate this then too
14724086_1169545973106877_497950785_o_zp
  • Like (+1 Rep) 3
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
The momentum here was lost. I'm trying something new here in an effort that those that follow this thread may learn something that otherwise would have not been learned. It's not about me asking a question and then giving you the answer. It's not about looking the answer up in the back of the book before you do the problem. It's about solving the problem to the best of your ability and whether you get it right or wrong you learn something in the process.
If I give you the answer, nobody benefits. Still want the answer?
 Share
  • Who's Online   0 Members, 0 Anonymous, 129 Guests (See full list)
