Explaining amp gain
Sufkayx
Hi
I may sound stupid for asking but im fairly new to car audio and have a little system consisting of
2 Alpine type R's 12d2 subs
4 Alpine type R component speakers
Lanzar OPTIDRIVE 2600 mono amp at 0.5 ohm which puts out 2600 at .5
4 cubic foot ported enclosure tuned at 36 hz
i have my subs wired to .5 and the subs are rated at 1k each whilst im using a 2600 amp
I am wanting to know what the gain is for im aware that its to match the output of the headunit with the amp but wanted to know if the gain determines how much power the amp recieves, at half gain will my amp get 1300 rms ?
or will my amp still put out 2600 but just need the deck volume to be turned up more than if the gain was at 3/4
Hope some one cant help
https://www.youtube.com/watch?v=Q48LQou_VhE
Gain is pretty much a multiplying factor. You are matching the output of the headunit to have maximum clean output out of the amplifier. The gain is not a volume knob, so it's not like at 1/2 gain you have (x) amount of watts. The gain attenuation is measured in voltage not watts. Also if your headunit has higher volt rca's, consequently your gain will be at a lower position than if you have lower volt rca's (1-2volt). So to get the maximum clean output, you first have to know where the maximum clean output of the head unit is, and then adjusting the gain to match that.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Ideally you use either a DD-1, or an oscilloscope. The multi-meter method doesn't work bc you have to know specifically what volume the head unit distorts at, and depending on a ton of factors you don't know what the max unclipped voltage from the amplifier should be.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Ohh i understand now,
The other day i was at a show and had my volume cranked up to around 30 of 35 and gains were set at around 75% after around 15 minutes i could smell some thing burning whent over yo my enclosure and smoke was coming out of the port. Took both subs out and they stunk so let them cool down and put them back in. I presume that was the voice coils burning but unsure whether it was b cause of clipping from the amp or because of me running 2 subs rated at 1k each of a 2600 watt amp. The cone of the subs were touch hot and the amp was warmer than it usually gets when i checked it
It was most likely from clipping.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
no problem man
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 699 Guests (See full list)
