out4u Posted November 18, 2016 Report Share Posted November 18, 2016 (edited) Ok so i have had an ongoing noise problem and have tried to solve and test in every possible way... i have a hiss i can hear through my tweeters (im sure id hear it through the mids to if they were as sensitive) it makes pops and changes hiss tone and all kind of goofy stuff mainly when i do anything else that uses power or ESPECIALLY if i move the headunit at all. it will do this with the car off and the rcas disconnected if the amps are on the noise is there, its not the amp for my tweeters because if i move the headunit it will make the mids amp pop n stuff to, it probably hisses quietly if i put my ear to it just havent checked... either way its not the amp. i lived with this issue for a long time cuz once i turn the volume up it doesnt increase the noise just the sound i should hear... so at high volumes its fine... oh yea and sometimes 1 tweeter will be out when i first get in my truck and once i turn it up itll click back on and work fine. reason i stopped living with it aside from being annoyed with it is because it started making my subs pop and instant protect my amp as soon as i turned on the headunit. ( i have 3 amps hifonics brx 2400 on 4 sundown 12's, a crescendo 550.2 on 4 8" pwx's , and a crescendo 800.4 on 2 ft1 super tweets on from front channels and 4 6x8 alpine coax on rear channels.) i went and bought a brand new headunit because i was starting to think it was that... its not and now here i am p.s it always makes noise when powered up and the only thing that changes the noise when i wiggle stuff is the headunit. UPDATE: ok so i guess it is the amp... my crescendo 800.4 hooked directly to a battery by itself just powered up with speakers hooked but no rcas and i still get hiss... and weird noise, so this amp is polluting my whole electrical system. hope i dont have to buy a new one... i feel like somethings just loose inside since it still works. UPDATE 2: its not my amp! i put the tweeters on the other crescendo and it does the same thing, i checked them 1 at a time they both do it so i dont think its the speakers wires, only thing i can think is there messed up and need new diaphrams? also is it even possible for the tweeters being messed up to cause all the problems i was having like noise when moving headunit or bass amp protect Edited November 20, 2016 by out4u Quote Link to comment Share on other sites More sharing options...
