2015 Chevy Sonic/Wall/4 PSI 15's/SA 6K/Active/Arc/CDT/Singer/US Alt/XS
3 hours ago, mcanderson0 said:
That port is SICKKK man.  Damn.  Thanks for the input, I was scared to cut too deep.  I saw on Wicks' build log that he used a slide-pull miter saw to quickly make a bunch of straight kerfs.  My miter is not a slide-pull, so I dont know if I want to cut all those kerfs with a circ saw and a guide, as that was a PITA last time.  Im also trying to make a 9.25" diameter kerfed curve, which may not be reasonable.  Thanks for the input, though.  So just leave a single or maybe two plies?
Yeah I'd say 1-1.5 plies when setting depth I usually just use a piece of scrap and get it dialed in to where I can bend it pretty easily. There is math to determine spacing on your cuts, I usually do the math and then test it on a small strip of wood 1-2 inches wide to make sure it will form to the curve that I need. If you have patience you can do it with just a circular saw and no guide, I think I made the port on the table saw though as it was pretty large. I also recommend screwing at strip or two to the back so that your kerf doesn't bend the wrong way and break. It also gives you something to grab and push when you're using a table saw.
You'll notice in this picture that the cuts are pretty much all the way through to the veneer but theres no lines on the outside.
Whereas in this one my cuts weren't deep enough and you can kind of see the lines. I usually just sand them a little if this happens and it makes them a little less apparent.
  • Replies 281
  • Created
  • Last Reply
On 2/12/2017 at 5:57 PM, mcanderson0 said:
Grounded my RCAs.  Noise prevention.
Separately grounded (middle)
So as it turns out, my headlights on my car cause a lot of chassis ground noise.  This RCA-ground concept would only (possibly) work if they were grounded to the battery post/bus.  Well, I dont have noise now that I removed the RCA ground, so I'll retackle that IF i receive hum/noise/pops in the future AND if I can attribute it to the headunit.  So for today, BYE noise:
IG @walledsonic
Used my miter saw to chop the post to the right angle for the welder:
So this 1.5" threaded turnbuckle is absolutely ridiculous.  Instead, I ordered the 1" version on McMaster Carr and I'll be returning this 1.5" version next week.  Either way, the turnbuckle will sit right about here:
IG @walledsonic
Fucking epic, don't want to call it a stripper pole anymore. Shit looks out of this world and almost overkill, really makes your build stand out.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Truth... A stripper might get hurt dancing on a pole like this. ?
IG @walledsonic
jeez, that turn buckle is WAY bigger than I thought it would be, fucking LOOOVE it dude!!!!!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Thats awesome, functionality and Art at the same time. Definitely different man, hats off to ya for the original idea and your application of it.
Heres the 1" turnbuckle.  Much more manageable.
With lockwasher and jam nut
This will go here, obv this is much smaller than the 1.5" version shown in a post above
IG @walledsonic
