chuey_316 Posted December 9, 2016 Report Share Posted December 9, 2016 Need a new amp and I have a chance to pick up a zx2500.1, I know they are 2ohm stable, but has anybody ran 1 at 1ohm daily? Running 1/0 power and we'll have 300a under the hood, with a deep cycle battery. Just trying to figure out if the amp can handle 1ohm daily before I grab it. 1999 Blazer AD-244 Alt (soon to be 2) HU / Pioneer P7800MP Sub / RE 18HC Amp / Shopping for a new one 7.71 cubes 118 sq" port area tuned to 34.9hz Link to comment Share on other sites More sharing options...
audiolamb6 Posted December 9, 2016 Report Share Posted December 9, 2016 not sure but i know the rest of the zx line only goes to 2 ohm so i would imagine it would be the same. Link to comment Share on other sites More sharing options...
hispls Posted December 9, 2016 Report Share Posted December 9, 2016 Hit or miss on those. I've seen it done without breaking the amp but I've ran the 1200.1 at low impedance without issue, but I have also had Kicker amps getting protect happy when you try to run lower than rated impedance.. I'd say if you intend to play music shop elsewhere for something designed to drive 1 ohm. Link to comment Share on other sites More sharing options...
chuey_316 Posted December 9, 2016 Author Report Share Posted December 9, 2016 I'll just run it at 4ohm for awhile and resell it on eBay. For $250 I can't pass it up. It'll do enough at 4ohm to keep my 18hc happy. 1999 Blazer AD-244 Alt (soon to be 2) HU / Pioneer P7800MP Sub / RE 18HC Amp / Shopping for a new one 7.71 cubes 118 sq" port area tuned to 34.9hz Link to comment Share on other sites More sharing options...
hispls Posted December 10, 2016 Report Share Posted December 10, 2016 I'll just run it at 4ohm for awhile and resell it on eBay. For $250 I can't pass it up. It'll do enough at 4ohm to keep my 18hc happy. That's a steal at 250$... in fact if you're buying it from Craigslist it probably is stolen. Link to comment Share on other sites More sharing options...
mothra Posted December 10, 2016 Report Share Posted December 10, 2016 the zx line up should be able to handle that load without an issue. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
STEvil Posted December 10, 2016 Report Share Posted December 10, 2016 1 ohm works fine if you tune it properly and dont push it off a cliff MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
chuey_316 Posted December 10, 2016 Author Report Share Posted December 10, 2016 Wasn't sure because I've done alot of reading on it, and it seems petty mixed. Some people saying they ran at 1, and others saying that theirs would protect at 1. Have to grab a clamp meter so I can check my box rise. May be fine wired at 1 after rise. Definitely a steal. Not stolen though. It's a guy I work with, that I've known for 20+ years. He paid $700 for it, used it in his girlfriends vehicle for a year or so before selling the car, and it's been sitting in his house ever since. 1999 Blazer AD-244 Alt (soon to be 2) HU / Pioneer P7800MP Sub / RE 18HC Amp / Shopping for a new one 7.71 cubes 118 sq" port area tuned to 34.9hz Link to comment Share on other sites More sharing options...
chuey_316 Posted December 11, 2016 Author Report Share Posted December 11, 2016 Well he brought it in today, and it's not the 2500, it's the zx1500. Was pretty bummed. Had planned to just run it at 4ohm till I seen that. I know they clamp around 2200 @1ohm, but I'm not gonna spend $250 on an amp to run it under imp. Guess I'll go with my original plan of either a brx2400.1d for the same price, or a refurbed rub1.2500d for $60 less. 1999 Blazer AD-244 Alt (soon to be 2) HU / Pioneer P7800MP Sub / RE 18HC Amp / Shopping for a new one 7.71 cubes 118 sq" port area tuned to 34.9hz Link to comment Share on other sites More sharing options...
Jay505nm Posted July 2, 2019 Report Share Posted July 2, 2019 No it will not handle 1 ohm stable no matter what kind of amps your alternator will produce or if using 2/0 cables. It sounds great at 2 ohms but if you plan on running a sub at a 1 ohm u better find a 1 ohm stable amp. Link to comment Share on other sites More sharing options...
