ShadeTreeMechanic Posted January 8, 2017 Report Share Posted January 8, 2017 Could be clipping. I member back in the day (early 90s) that big subs often didn't sound good at higher frequencies. I would often cross them over low pass around 60hz. Then I would use smaller woofers for 60hz and up. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
