Skar TxL box plans
ThreehundredC
So just picked up a skar txl.  12.  Goin in a 2008 dodge charger trunk of i could get a box plan for it. That would help Greatly. I will be running a sksr 4500 amp. have wood ready to cut
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Enclosure Specifications:
Fb = 34 Hz
Vb = 3 ft^3
External Height = 14 in
External Width = 34 in
External Depth = 19.5 in
Port Width = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 14
Left & Right Sides = 17 1/4 x 12 1/2
Top & Bottom = 34 x 17 1/4
L Port Internal Assembly Parts:
Front to Back = 13 1/2 x 12 1/2
Extension = 9 x 12 1/2
  • Who's Online   1 Member, 0 Anonymous, 1831 Guests (See full list)
