Wannabe Posted January 21, 2017 Report Share Posted January 21, 2017 I have my volt meter wired to the power on my sub amp and I noticed it never turns off could this small amount of power drain a battery ? this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
yurvalentine Posted January 21, 2017 Report Share Posted January 21, 2017 It depends on the battery, the meter, and if it's cold outside that won't help. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 21, 2017 Report Share Posted January 21, 2017 Eventually it could I guess. It draws such a small amount of power that it would probably be ok on a daily driver. On a vehicle in storage for months, maybe not a good idea. What voltage does it read after sitting overnight? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Wannabe Posted January 21, 2017 Author Report Share Posted January 21, 2017 I have an xs power d3400 and idk about voltage overnight cause I just put it in a hour or 2 ago but I will look and yes it's always cold here this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 22, 2017 Report Share Posted January 22, 2017 what volt meter? usually they have 3 wires to hook up. Positive, negative, and a remote that turns the volt meter on/off. Link to comment Share on other sites More sharing options...
Wannabe Posted January 22, 2017 Author Report Share Posted January 22, 2017 It inlet had a power and a ground, it is xscorpiian this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
Wannabe Posted January 22, 2017 Author Report Share Posted January 22, 2017 http://m.ebay.com/itm/311739019176 this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs Link to comment Share on other sites More sharing options...
Ron36 Posted January 22, 2017 Report Share Posted January 22, 2017 Check your voltage one night and then check it in the morning see what the drop is better be no more then half a volt even that might be to much. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 22, 2017 Report Share Posted January 22, 2017 IIRC most volt meters draw around 50ma. That shouldn't be enough to hurt you, but if you car's going to be sitting for more than 3-4 days I'd unplug it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
SnowDrifter Posted January 22, 2017 Report Share Posted January 22, 2017 If you're concerned about it you can wire in a transistor or a relay to switch it on and off with the ignition ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
