jessdabest77 Posted January 22, 2017 Report Share Posted January 22, 2017 I'm about to build a ported box for two 12" Sundown SA's and was wondering if there's any difference in a kerfed port to a regular slot port with a roundover? I knew they look nice but is that all it's for or does it perform better? Regular slor port or kerf port will have 45's,bracing,and be double baffeled,thank's in advanced. Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted January 22, 2017 Report Share Posted January 22, 2017 A kerf port will always give you better air flow and performance over 45 degree corner. How much performance tho really depends on the specific application. In your case i don't really think it would make that much of a difference being as it's a fairly low power application. Link to comment Share on other sites More sharing options...
neuspeedescort Posted January 22, 2017 Report Share Posted January 22, 2017 kerfing in your application would be more of a flare in design then a need. but go for it. kerfs look beautiful when done and painted properly. Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 22, 2017 Report Share Posted January 22, 2017 Also take into consideration that the majority of your kerf is not counted as port length, and that the kerf will take up more volume inside the box volume compared to a slot port (even more volume if you put a giant 45 behind it on the inside of the box). So be sure to calculate those things. Realistically speaking in a musical application you wont be able to tell the difference between a kerfed port or a traditional slotted port. Link to comment Share on other sites More sharing options...
jessdabest77 Posted January 22, 2017 Author Report Share Posted January 22, 2017 Thanks guy's. Since I brought up the Sundown's does anyone know a good size ported box for a pair of SA Rev 3 12's on a 2200 watt amp? Box size,port size and tunning Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted January 22, 2017 Report Share Posted January 22, 2017 I would build it at 4 - 4.5ft^3 after displacement with about 70in^2 of port area tuned to 33hz Link to comment Share on other sites More sharing options...
