reedal Posted January 31, 2017 Report Share Posted January 31, 2017 I've had my laptop since 2011/12-ish. Last year I was ripping DVDs no problem, now I'm home and want to continue the process, and none of my DVDs even show up as being in the drive (via My Computer). My WinX DVD Ripper Platinum doesn't show them, nor any media playback programs (windows media/center, VLC, iTunes). But if I pop an Audio CD in, it shows up just fine in My computer and the media playback programs. Anyone know any tips to try? The DVDs aren't damaged/scratched/dirty. i'd prefer to not have to buy an external optical drive, but if that's the only solution, I don't have a clue what to look for, so any help there would be great as well. Thanks Edit: i should add, it does try to read the DVDs, it makes a lot of clicking and whurring noises for a minute or so before it gives up. These are original DVDs as well, not burned copies or anything. i just don't get why it used to work just fine, and now it only reads CDs SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 31, 2017 Report Share Posted January 31, 2017 The only thing I can think of is that the driver for it was updated to the wrong driver? Or maybe the driver is corrupt? Maybe try reinstalling the driver for it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
reedal Posted January 31, 2017 Author Report Share Posted January 31, 2017 5 minutes ago, ShadeTreeMechanic said: The only thing I can think of is that the driver for it was updated to the wrong driver? Or maybe the driver is corrupt? Maybe try reinstalling the driver for it. I tried that. No avail. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
bsneon98 Posted January 31, 2017 Report Share Posted January 31, 2017 It definitely sounds like a driver issue, or a OS issue suddenly. A laptop optical drive can be found cheap on ebay. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/ Link to comment Share on other sites More sharing options...
fosgatefan821 Posted January 31, 2017 Report Share Posted January 31, 2017 Can you buy a replacement drive? I did years ago for my old laptop I had. What is the model? 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery Link to comment Share on other sites More sharing options...
reedal Posted January 31, 2017 Author Report Share Posted January 31, 2017 It's a TSSTcorp CDDVDW TS-L633C ATA Device according to device manager SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
bsneon98 Posted January 31, 2017 Report Share Posted January 31, 2017 http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=TS-L633C&_sacat=0 most any sata optical drive should work. May have to transfer mounting bracket and bezel but theres a ton of direct replacements out there. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/ Link to comment Share on other sites More sharing options...
reedal Posted January 31, 2017 Author Report Share Posted January 31, 2017 9 minutes ago, bsneon98 said: http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=TS-L633C&_sacat=0 most any sata optical drive should work. May have to transfer mounting bracket and bezel but theres a ton of direct replacements out there. Ok, thank you. I can work my way around software mostly, but when it comes to what hardware is compatible, etc., I'm clueless. So that helps. Hopefully it doesn't come to that. I'm still looking through some troubleshooting steps online, so hopefully something pops up to where I don't have to replace the drive. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
bsneon98 Posted January 31, 2017 Report Share Posted January 31, 2017 Just now, reedal said: Ok, thank you. I can work my way around software mostly, but when it comes to what hardware is compatible, etc., I'm clueless. So that helps. Hopefully it doesn't come to that. I'm still looking through some troubleshooting steps online, so hopefully something pops up to where I don't have to replace the drive. No problem man. I wish you luck! Worst case scenario, you remove the top or bottom case to get the drive out but on the older units the optical drive is usually one screw and it slides out. All depends on the laptop. There also should be a Disc shape stamped on the plastic with a triangle pointing to the screw. Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/ Link to comment Share on other sites More sharing options...
reedal Posted January 31, 2017 Author Report Share Posted January 31, 2017 Well now it's working again all of a sudden. I guess we'll see how long it lasts. Thanks for the help guys. I'll keep the advice in the back of my mind for the next time it acts up SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
