Will this charger work for XS power batts
Curious if anyone has used or is using this charger. Would be nice if I could get a charger this cheap compared to the XS power brand.
http://s1168.photobucket.com/user/mlentz2728/media/New Sub Box Build/AE4EC27F-2854-4F0D-8688-A901D1776519_zpslkxxvkqr.jpg.html
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Well, it says AGM on it so that's a good start, and you're only charging one XS batt...so I guess it could work to stay on a budget... but I got the XS chargers for my XS batts and would suggest the same. I've got an intellicharger for my 3100's and a lithium charger for the 30k I've got. If you plan to ever upgrade your system you will probably need more batteries and then I believe the intellicharger would be worth it. There's plenty of other chargers out there that are just fine but I've had walmart chargers crap out on me years ago.
97 Suburban
8 custom PSI Platform 3 18's
As others said, if its just one battery get the smaller ctek, or the Noco Genius g3500 charger for about $60 (which is a 3.5amp charger). https://www.walmart.com/ip/46605772?wmlspartner=wlpa&adid=22222222227034478241&wl0=&wl1=g&wl2=c&wl3=91232399088&wl4=pla-127892511888&wl5=9018759&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=46605772&wl13=&veh=sem
Some of those cheap chargers like that duralast one are made by Schumacher, and iirc I heard a lot of people cooked batteries using those cheap chargers because they dont monitor the voltage like they should, never shut off when the battery was full, etc.
Cool. Thanks guys. I will get one of the recommended ones on order.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Ctek 7002 is what I use for my d3400 and 4 d3100s great charger little over $100-140. Has recovery mode too
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
XS Power batteries like a certain charge voltage. Check with XS Power for a list they have of capable chargers
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I used to use this and it worked great but I ran a large bank so it took a while to do much but I usually left it on overnight which was plenty of time for it to do it's thing.  I found it online for like $90 shipped.  I see they now make a 15 amp tho.....it's pretty much same as a Ctek which some people on here I have seen frown upon.
https://no.co/g7200
I now use this one and love it, only had it less than a year but been working great, a little more powerful.
https://www.griotsgarage.com/product/microprocessor-controlled+battery+charger-maintainer.do?code=PPCPLG&gclid=CjwKEAiA8dDEBRDf19yI97eO0UsSJAAY_yCShdTj-xXUgOZmu5w4_4S4CmRj0uMVSZ43sBzDnAJ4ExoCkqjw_wcB
Pretty much the same as the MAC tools one... (i think)
https://www.google.com/search?q=mac+tools+battery+charger&rlz=1C1CHBF_enUS711US711&espv=2&biw=1463&bih=748&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj345rx1_TRAhXHz1QKHc8aBvAQ_AUIBygC#imgrc=v0VMQtNrDPktlM:
Or...
https://www.amazon.com/SOLAR-PL2320-Pro-Logix-Battery-Charger/dp/B007ESQW08
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   1 Member, 0 Anonymous, 1613 Guests (See full list)
