RedFred Posted February 10, 2017 Report Share Posted February 10, 2017 15 hours ago, BassMunky said: what your alt? 270a JS Ultimates. 2 runs of 2/0 throughout the vehicle Link to comment Share on other sites More sharing options...
BassMunky Posted February 11, 2017 Author Report Share Posted February 11, 2017 So should I put them on charger once a week or month since I just changed my alt to a brand new stock one that pit out 100 amp at max? System a rf 1500 bdcp and a sundown 100x4 on 2 12 ascendant audio chaos. Big 3 does the Schumacher 1200 have a recondition Mode? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted February 12, 2017 Author Report Share Posted February 12, 2017 Anyone????? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted February 12, 2017 Author Report Share Posted February 12, 2017 Ctek 7002 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
reedal Posted February 12, 2017 Report Share Posted February 12, 2017 I don't know if the Schumacher does. The CTEK 7002 does. It's what I have. You just set it to recondition (super easy, just plug it in and push the button until recond. Lights up) and then it assesses where your battery is at. If it needs it, it will start the process. If not, it gives it a float charge until you take the charger off of the battery. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
BassMunky Posted February 15, 2017 Author Report Share Posted February 15, 2017 Does the schumacher 1200sc/a have a desulphation mode? Does someone own this model? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted February 17, 2017 Author Report Share Posted February 17, 2017 bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted February 17, 2017 Report Share Posted February 17, 2017 You could probably google it? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
BassMunky Posted February 18, 2017 Author Report Share Posted February 18, 2017 Ok I did never really help. Some review say it has a desulphate mode. Soo. Not too sure if it a selection or the machine just detects it and goes into that mode automatically. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted February 19, 2017 Author Report Share Posted February 19, 2017 Bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
