sundownaudio Posted February 9, 2017 Report Share Posted February 9, 2017 Is network mode for me poineer AVH-X3800BS my current set up is can i use network mode with the current set up ? also what would be a good crossover starting point for the highs mid and lows and what slopes to use ? 4 faital pro 6fe200 in the door panels on a 2 channel rockford p500x2 4 silk dome tweets on 2 channel rockford p300x2 1 12" sa12 sundown audio bass on a 1200.1d rockford prime amp Link to comment Share on other sites More sharing options...
sundownaudio Posted February 10, 2017 Author Report Share Posted February 10, 2017 Can someone help ? Link to comment Share on other sites More sharing options...
bcbrassard Posted February 10, 2017 Report Share Posted February 10, 2017 Running active takes knowledge and experience IMO. Is your equipment capable of it... Sure. Are you able to tune it right? Sometimes keeping it simple can yield better results. Tons of internet info and info on the this forum about running active. I would do your own research to come to the conclusion weather you should or shouldn't. I would say if your asking about crossover points that might be a good indication you shouldn't. I just finished a budget build using the Faital Pro 4" passive with a tweeter and when installed properly with deaden-er and acoustic foam sounded amazing to me for the price. I hope you have the same performance with your 6". Link to comment Share on other sites More sharing options...
