how much electrical i ened for 2 5ks at 1 ohm?
On 3/27/2017 at 2:41 PM, walwalka said:
Dat overkill doe.
Change your icon you whore.
  • 3 weeks later...
thought id update the topic. Did the recones and got everything goin, tuned amps with track 3 of dd-1 ( max sound quality) voltage seems ok for now but I tuned everything at 0 subwoofer output and I'm at -2 subwoofer output for break in period.
I did get into the 12s at 2 k engine rpms for a bit today tho
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Whaaat?
"But you need 3 more batts and another alt bro"
Hehe.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
another update. I did finally go full tilt at idle for an after work demo session, my car idles around 1300-1400 rpms (raised idle for more alt output) and I did get sub 12 volts quite quickly, within maybe 20 seconds. on the road home I dropped to around 12.9 at full tilt.
Id say 3 batteries is not enough for 2 5ks. next plan will be a bank of caps to help shore up the situation
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
  • 2 months later...
On 4/17/2017 at 3:19 PM, hdorre said:
Whaaat?
Hehe.
He he turns out he really did Need 3 more batts and a alt. Unless you like smoke coming from your equipment.
Youre right. 12s kill equipment. Why even bother with batts then? Caps and alts, no?
LMFAO so true
:blush:
A few thoughts here . . .
10,000 Watts of Class D amplifier power
10,000W / 75% Amplifier Efficiency = 13,333W Input
13,333W / 13.8 VDC* = 966A
966A x 50% Duty Cycle for music played back at clipping = 483A
*let's be realistic, shall we . . .
So . . . 966A on sine waves is a reality, assuming you can maintain the 13.8 VDC - which he clearly cannot.
Alternators = Voltage Sources of up to 14.4 VDC (12V charging systems of course . . . )
Batteries = Voltage Sources of up to 12.6-12.7 VDC (fully charged 12V battery)
[Once output of the alternator is exceeded, the best voltage that can be maintained is the nominal voltage of the batteries.  Personally, I prefer 13.8 VDC to 12.anything VDC.]
320A Alternators typically have reduced output between idle (800 engine RPM) and cruise (2,000 RPM) as compared to 240A or even 270A alternators.
Personally, I'd swap the single 320A unit for a pair of 270A units to gain output in the sweet spot.  The output between idle and cruise could be triple that of the single 320A unit!  Then, if I still wasn't happy with the voltage I could maintain when jamming at full tilt, I'd add (5) quality 1F capacitors to each of the 5Kw amplifiers - wired within 12" of the amplifier, of course.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
  • Who's Online   1 Member, 0 Anonymous, 1850 Guests (See full list)
