Fusing slightly above recommended?
Alright so I know how this usually goes, "if you have to ask don't do it" but I have a fused distribution block from sky high (1/0 to dual 4 gauge) and I have my two amps ( saz1200d and sae 50.4) I have a fuse for my 1200d but the lowest I can find in ANL around me, and from distributors I trust, is a 60 amp but the sae 50.4 recommends a 50 amp fuse. Would it be okay to run a 60 amp even though that's 10 amps higher than what the amp is supposed to have? If it's not I'm sure I'll just have to either find a fuse block that does MANL fuses or run two seperate fuse blocks. Thanks! Greg
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
22 minutes ago, reedal said:
Snap! Totally missed that one! Thanks! That works perfect!!
stock alt 105a
The fuse at the distribution block is to protect the wire going to the amp. If you want to protect the amp then put a fuse block at the amp. If the amp has on board fuses then a fuse block is not needed.
Pioneer 80PRS
Totally didn't think of that. Oh well! Can't hurt anything! Haha
stock alt 105a
  • Who's Online   1 Member, 0 Anonymous, 1034 Guests (See full list)
