Taramp's 20.2KW Noise Issue
Nicholas Rechichi
Has anyone seen this noise before??
Long story short I brought a second hand amp, hooked i all up and it does this.
Video pretty much shows it all
So my mate and I,
  • tested different RCA's.
  • Sounded fine through the phone 3.5mm to RCa, although there was lots of trebble (bad filters I'd say)
  • Used a head unit which was in his car but got a loud humming noise instead (probably because h/u not connected to my cars electrical system)
  • amp was tested in his vehicle (he has no issues) Still done it
I should also mention I had no issues at all with the previous Taramp's Hd8000.
any help would be apreciated. Thanks!
Bump.
Fixed the engine noise. Found a bad head unit ground.
This is quoted from Taramp's themselves "The noise that occurs with the system off is characteristic of the amplifier". Now it is really a bad noise and gets louder as you turn the gain up. Very little noise with the gain on minimum.
Please if anyone has any info on these amps, I would like to know if your one makes this noise too.
Thanks
Do you have an amp repair place down under?
IG @walledsonic
Does it do it with the gain all the way down?
Pioneer 80PRS
Does it go away if you unplug your RCA's?
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 241 Guests (See full list)
